Topic: ATMEGA328P U standalone (Read 164 times) previous topic - next topic
HannesM
Hello all!
I am using an Arduino UNO to communicate with a GPS and a SIM modul. Arduino UNO is to big for my application, so I want to create my own circuit board with the ATMEGA328P U, where I just use 4 Dig Inputs.
My question now is what to do with the other digital Inputs? Should I connect them with +5V or GND?
Especially the AREF Pin- should I leave it blank or do i have to connect it with +5V or GND?
Thanks for the answers :)
spycatcher2k
Unused IO pins, leave unconnected. AREF, bypass to GND.
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
HannesM
I would appreciate it if you could share your source of information with me, because I have to justify why I did this and I always thought unused I/Os have to get a fixed voltage level from a pull up resistor or have to be connected to GND?
Thanks a lot :)
DrAzzy
Atmel recommends setting unused pins to input with pullups enabled, and not connecting to anything. Though tests of power usage in those conditions that nick gammon conducted seem to imply that this doesn't yield the improvement in sleep power consumption that would be expected
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
HannesM
Very useful Information thanks!
But I haven't found the researches of "Nick Gammon" could you pleas send me a Link?
The datasheet of ATMEGA328 also says "If some pins are unused, it is recommended to ensure that these pins have a defined level." & "If low power consumption during reset is important, it is recommended
to use an external pull-up or pull-down."
Do you know what is the usual resistance I should use in this case?
Do I have to define the I/Os as Inputs in the Arduino IDE or whrer should I do this?
DrAzzy
Is low power *DURING* reset required? Usually the chip is in reset for such a short time (the duration that reset is held down) that you don't care about the power usage during reset, and the internal pullups are fine.
Also, do not create multiple threads about the same topic, it is a violation of forum rules because it confuses people answering questions and makes it hard for prospective responders to know the full context of the issue.
HannesM
#6
Mar 20, 2019, 09:02 pm Last Edit: Mar 20, 2019, 09:27 pm by HannesM
Should be fine if I just use the internal pull up.
Two last questions: Do you know how to activate the internal pull up in the IDE?
                            Where can I find the post of "nick gammon" you talked about in your previous post?
Sorry won't happen again!
WattsThat
Vacuum tube guy in a solid state world
