Topic: SIM800L not responding to AT command on Serial Monitor (Read 79 times) previous topic - next topic
Samkusenuh
Mar 20, 2019, 02:22 pm Last Edit: Mar 20, 2019, 02:38 pm by Samkusenuh Reason: markup
Dear fellow Arduinions,
Im currently connecting my Arduino with my SIM800L module according to https://lastminuteengineers.com/sim800l-gsm-module-arduino-tutorial/
The SIM800L module is blinking once in 3 sec so no issues there.
However, when I want to send my first "AT" command via Serial Monitor I get no response at all...
baudrate is set to 9600 and "both NL & CR" is selected in the monitor.
The module is powered with a LiPo 3.7 v 1500 mA battery.
I already shortened 2 connections from the battery to the sim module because other forums on the internet mentioned that long cables are a common cause for not responding. (see attached foto's)
Any ideas where to possible cause may be hidden? Thank you kindly in advance.
Samuel Kusenuh
freaklabs
Is there a USB interfacce where you can test things? If not, then best to write up a simple interface to echo commands to the GSM module. Also make sure the baudrate is set correctly on it. Sometimes the modules may be set at a different baudrate than you expect. Make sure 9600 is the default in the datasheet.
FreakLabs
Wireless Technology for the environment, wildlife, and agriculture
https://freaklabs.org
https://hackerfarm.jp
Twitter: @freaklabs
Samkusenuh
Hi Freaklabs,
thanks for the valuable input.
I want to try your recommendation. With testing via USB interface, I would probably need as USB-to-serial device like the one in the following link right?
https://www.electroschematics.com/wp-content/uploads/2017/12/4-Serial-Setup.jpg
Or is it possible to do the testing via the arduino, similar as how I am currently (trying) to interface with the SIM800 module.
Cheers,
Sam
freaklabs
Hi Samkusenuh.
I'd recommend to remove the Arduino MCU from its socket and use the board as a USB/serial interface. Otherwise, pick up a USB serial interface and try to talk to the board. Once you have established that communications is possible, then try to automate it via software.
FreakLabs
Twitter: @freaklabs
