Topic: Read Temperature with Si7021 sensor by using Sonoff TH (Read 187 times) previous topic - next topic
atjackie1985
Hi everyone.
 Please help me to read humidity and temperature from Si7021. I have Sonoff TH and use Si7021 Sensor.
I see example at https://learn.adafruit.com/adafruit-si7021-temperature-plus-humidity-sensor/arduino-code
but it's not work. no show anything. Pls help me...
Code: [Select]
#include "Adafruit_Si7021.h"
Adafruit_Si7021 hum_sensor = Adafruit_Si7021();
  hum_sensor.begin();
      // Si7021
    float h = hum_sensor.readTemperature();
    float t = hum_sensor.readHumidity();
    Serial.print("Humidity: "); Serial.print(h); Serial.print(" %\t"); Serial.print("Temperature: ");  Serial.print(t); Serial.println(" *C ");
    delay(2000); //Delay 2 sec.
PaulS
Quote
Print something before and after trying to read the temperature, and before and after trying to read the humidity.
Do you still get nothing?
pylon
Check the return value of the begin() method. If it's false you're wiring is wrong.
atjackie1985
Yes. I try to print something that you recommend. Show result as below, I think it's jack and need pin or not?
08:50:10.876 ->  Start print begin
08:50:11.045 -> 0 Start print before
08:50:11.045 -> Humidity: nan % Temperature: nan *C
08:50:11.045 ->  Start print after
But if i use AM2301 it's work by this code below ( No work for Si7021 )
Quote
// Sensor AM2301, AM2302
#include <DHT.h> // Adafruit DHT
#include <Adafruit_Sensor.h> // Adafruit Unified Sensor
#define DHTPIN 14     // what pin we're connected to
#define DHTTYPE DHT22   // DHT22  (AM2302)  DHT11
DHT dht(DHTPIN, DHTTYPE);
  delay(5000);
  dht.begin(); // Humidity and Temperature
//       AM2302
    float h = dht.readHumidity();
    float t = dht.readTemperature(); // Read temperature as Celsius
    if (isnan(h) || isnan(t)) {  Serial.println("AM2301 - Failed to read from DHT sensor!"); }
pylon
Quote
Getting an output with nan is not the same as getting nothing!
Quote
The AM2301 (DHT22) is wired differently, it using kind of a 1-wire bus (not to be confused for a Dallas OneWire bus) but the SI7021 uses I2C. Most probably the wiring is wrong. Post a wiring diagram of your setup (may be hand drawn)!
freaklabs
You might need to make sure the device is powered and the ground is intact. Getting NaN means that you're likely getting garbage from the serial. Perhaps use a hex monitor to see what you're getting? Trashed data could come from bad GND and of course incorrect wiring.
FreakLabs
Wireless Technology for the environment, wildlife, and agriculture
https://freaklabs.org
https://hackerfarm.jp
Twitter: @freaklabs
atjackie1985
#6
Mar 25, 2019, 02:35 am Last Edit: Mar 25, 2019, 02:37 am by atjackie1985
This is our circuit at https://ibb.co/WfH2JhY. I use Sonoff Si7021 and Sonoff model TH.  Actually I have tested with old sonoff code. It's work but I try to flash via using our code. it's not work. I don't understand why is not work. I guess that about pin because all examples no use jack they use i2c as I know. If I misunderstand pls help us. :-)
atjackie1985
Pls help me on this case if someone can read humidity and temperature.
pylon
Quote
First: post picture here into the forum system and not to external sites that delete the link after short time frames. Second: Do you really think that this picture allows to see the circuit? Post schematics of the used components! And a wiring diagram (the white color on the connection doesn't allow to see any wiring).
atjackie1985
Schematic link: Sonoff TH
https://www.itead.cc/wiki/images/3/39/Sonoff_TH10A%2816A%29_schmatic.pdf
Schematic link: Sensor Si7021 Humidity
https://www.itead.cc/wiki/File:Sonoff_Si7021_Sensor_Schematic.pdf
pylon
The Sonoff sensor contains an Si7021 sensor but it's not directly connected to the Sonoff TH but by some microcontroller that seems to translate the I2C signals to a kind of one wire bus.
There are some indicators on the Itead Wiki that this single wire bus is compatible with DHT11/22 sensors. So try to read the sensor using that protocol but you won't be successful if you request data as if it was a directly connected SI7021.
