Topic: Bootloader Error (Read 92 times) previous topic - next topic
lgpalacioa
Somebody have had this problem while is uploading the bootloader??
Error while sending: missing configuration parameter 'upload.tool'
DrAzzy
You're using an incomplete board definition that omits the upload.tool parameter, or you're using a board definition from pre-1.6 days with a modern version of the IDE.
For most common use cases, there's a modern board package available, usually through board manager - if you tell us what you're bootloading, we can point you to the right one. Unfortunately a lot of pre-1.6 tutorials that tell people to modify boards.txt (which nowadays you should never be doing) are still being used, when the correct solution is to use an existing board package.
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
