Topic: compiling error (Read 528 times) previous topic - next topic
Vik321
original
Code: [Select]
This code has three "print modes":
Line 41 can print to terminal which frequency is most dominant.
Lines 47-49 can print to terminal the values of each bin.
Line 49 will print can print to plotter the visualization of all the bins.
//https://www.norwegiancreations.com/2017/08/what-is-fft-and-how-can-you-implement-it-on-an-arduino/
//https://github.com/kosme/arduinoFFT/blob/master/Examples/FFT_04/FFT_04.ino
#include "arduinoFFT.h"
#define SAMPLES 128             //Must be a power of 2
#define SAMPLING_FREQUENCY 1000 //Hz, must be less than 10000 due to ADC
arduinoFFT FFT = arduinoFFT();
unsigned int sampling_period_us;
unsigned long microseconds;
double vReal[SAMPLES];
double vImag[SAMPLES];
    sampling_period_us = round(1000000*(1.0/SAMPLING_FREQUENCY));
    /*SAMPLING*/
    for(int i=0; i<SAMPLES; i++)
        microseconds = micros();    //Overflows after around 70 minutes!
       vReal[i] = analogRead(0);
        vImag[i] = 0;
        while(micros() < (microseconds + sampling_period_us)){
    /*FFT*/
    FFT.Windowing(vReal, SAMPLES, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
    FFT.Compute(vReal, vImag, SAMPLES, FFT_FORWARD);
    FFT.ComplexToMagnitude(vReal, vImag, SAMPLES);
    double peak = FFT.MajorPeak(vReal, SAMPLES, SAMPLING_FREQUENCY);
    /*PRINT RESULTS*/
    //Serial.println(peak);     //Print out what frequency is the most dominant.
    for(int i=0; i<(SAMPLES/2); i++)
        /*View all these three lines in serial terminal to see which frequencies has which amplitudes*/
        //Serial.print((i * 1.0 * SAMPLING_FREQUENCY) / SAMPLES, 1);
        //Serial.print(" ");
        Serial.println(vReal[i], 1);    //View only this line in serial plotter to visualize the bins
    //delay(1000);  //Repeat the process every second OR:
    //while(1);       //Run code once
in original
Code: [Select]
AWOL
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
Vik321
so why
Code: [Select]
amplitude[i] = analogRead(0);
is causing the problems
AWOL
so why
Code: [Select]
amplitude is not an array.
It doesn't take a subscript.
lesept
Ok, here are the questions you need to ask yourself
  • What is it you measure with your sensor, using analogRead ? Amplitude or real part?
  • What do you want to display to the user or make calculations on?
If you can answer these questions, then you can write your code.
If you want to display or calculate something from the real and imaginary parts, such as the FFT, then you need to store those values in arrays and only those values. In this case the amplitude is just an intermediate variable that you use once and don't need to store for later use.
If you need to calculate or display all the amplitude values, then you have to store them in an array.
To declare an array, so as you already did
Code: [Select]
double whatever[SAMPLES];
And to store or use the i-th value of this array, use whatever [ i ]
All the variables you don't store in arrays, you just declare them as global variables or local when you need to use them
I hope this is clear, because I am not a native English speaker (at all)
A force d'essayer on finit par réussir... Donc, plus ça rate, plus on a de chances que ça marche (proverbe Sharduinok).
johnwasser
The results
@johnwasser
noise, no respond to input signal
I think the problem is in your math.  I take no blame for your math mistakes. :)
WHY are you mashing a 32-bit float into an 8-bit int and then storing the result in a 32-bit float?
The sine wave has a range of -1.0 to +1.0.  You divide that value by 2 for some unexplained reason and get a range of -0.5 to +0.5.  THEN you multiply by whatever you got from the analog input, a value from 0 to 1023.  WHAT IS THAT VALUE DOING?  If it is just a 'gain' control to set the amplitude of the signal, you should probably divide it by 1024.0 to get a gain from 0.0 to (about) 1.0 and use the same value for all of the samples!  If it is an audio signal that you want to multiply into the sine signal (for whatever reason) you should probably subtract 512 and divide it by 512.0 to get a -1 to +1 signal.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Vik321
in case that the numbers are too high, I divided the results by 100 instead of 2, still no respond to input.
Vik321
#22
Mar 25, 2019, 12:29 am Last Edit: Mar 25, 2019, 12:34 am by Vik321
Thanks to your suggestions I get something with this code.
Code: [Select]
#include <math.h>
#define SAMPLING_FREQUENCY 5000 //Hz, must be less than 10000 due to ADC
const double signalFrequency = 1000;
double amplitude[SAMPLES];
double cycles = (((SAMPLES - 1) * signalFrequency) / SAMPLING_FREQUENCY);
  sampling_period_us = round(1000000 * (1.0 / SAMPLING_FREQUENCY));
  int i;
 //float amplitude[i];
  /*SAMPLING*/
  /*SAMPLING*/
  for (int i = 0; i < SAMPLES; i++)
   // amplitude = analogRead(0);
    //lesept
    //vImag[i] = int8_t((amplitude[i] * (cos((i * (twoPi * cycles)) / SAMPLES))) / 2000.0);
    //vReal[i] = int8_t((amplitude[i] * (sin((i * (twoPi * cycles)) / SAMPLES))) / 5000.0);
       vImag[i] = int32_t((amplitude[i] * (cos((i * (twoPi * cycles)) / SAMPLES))) / 2000.0);
    vReal[i] = int32_t((amplitude[i] * (sin((i * (twoPi * cycles)) / SAMPLES))) / 5000.0);
    //johnwasser, pic sine
    //vReal[i] = int8_t((amplitude * (sin((i * (twoPi * cycles)) / SAMPLES))) / 2.0);
    // vImag[i] = int8_t((amplitude * (cos((i * (twoPi * cycles)) / SAMPLES))) / 2.0);
    //  vReal[i] = int8_t((2 * (sin((i * (twoPi * cycles)) / SAMPLES))) /2.0);
    // vImag[i] = int8_t((2 * (cos((i * (twoPi * cycles)) / SAMPLES))) / 2.0);
    while (micros() - microseconds < sampling_period_us)
  /*FFT*/
  /*PRINT RESULTS*/
  for (int i = 0; i < (SAMPLES / 2); i++)
Vik321
now I need to replace
Code: [Select]
by "peak" which is input  frequency, this attempt does not work
Code: [Select]
int  signalFrequency = peak ;
int peak ;
The error
Code: [Select]
peak:6:24: error: 'peak' was not declared in this scope
exit status 1
lesept
You need to read some basic information about the structure of a Arduino program.
In the part before the setup, you can mainly declare variables and libraries. Declaring variables can be just like this
Code: [Select]
int X;
or assign them a value
Code: [Select]
int X=0;
but you cannot put instructions such as
Code: [Select]
X = Y;
especially if Y was not declared before, which is what you tried to do.
So this
Code: [Select]
int  signalFrequency;
int peak ;
is correct, then in the setup or the loop you can have
Code: [Select]
wildbill
The compiler is complaining that peak doesn't exist when you try to use it because you declared it after the attempt to use it. Moving the declaration up would make that go away.
However, it's probably not what you want, because peak won't contain anything useful. I'm guessing that you have some other code that reads it. Post it all for better answers.
PaulS
signalFrequency and peak were doubles. Why did you change the type to int?
Vik321
Post #15 = original code /*PRINT RESULTS*/ //Serial.println(peak); //Print out what frequency is the most dominant.
The results are printed without declaring "peak"
Vik321
I am trying a different versions to eliminate the errors
