Topic: atmega 2560 i2c issues (Read 81 times) previous topic - next topic
gary36
Hi
I am using atmega2560 pin20/21 for general purpose I/O. But to my surprise the output always stays high. Apparently no activity. What could be the reason?
neiklot
Maybe your code, but only you can see it right now ;)
gary36
Here is the declaration
#define a 20
#define b 21
 pinMode(a, OUTPUT);
 pinMode(b, OUTPUT);
digitalWrite(a, LOW); // Pin stays always high
neiklot
What are you using to check it?
Wawa
A Mega has a shipload of other pins.
Why are you trying to use the hardware I2C pins for anything else than I2C.
Note that the analogue pins can also be used as digital I/O.
Leo..
gary36
Issue resolved. Problem was in hardware. I2c pins were connected to EEPROM pulled to VCC.
GolamMostafa
#6
Mar 25, 2019, 03:47 pm Last Edit: Mar 25, 2019, 03:49 pm by GolamMostafa
No! The issue is now resolved. I have executed the following codes in my MEGA; the states of the DPin-20/21 are changing at 1-sec interval; the events have been observed by connecting 2.2k + LED circuit. Please, upload the sketch in your MEGA; if the pins are not toggling, then there is something wrong with the pins of your MEGA not for all MEGAs!
Code: [Select]
  pinMode(20, OUTPUT);
  pinMode(21, OUTPUT);
  digitalWrite(21, HIGH);
  digitalWrite(21, LOW);
