Topic: i am Facing a lot of errors In my code .please help me .. (Read 186 times) previous topic - next topic
hydrabomb
EVERYTHING IN THE CODE I CHECKED SEEMS TO BE CORRECT ....BUT THESE ERRORS ARE still showing up..
Arduino: 1.8.7 Hourly Build 2018/09/12 02:23 (Windows 10), Board: "Arduino/Genuino Uno"
sketch_mar25a:10:3: error: variable or field 'setup' declared void
sketch_mar25a:10:21: error: expected ')' before ';' token
sketch_mar25a:11:2: error: 'myservo' does not name a type
  myservo.attach(9);   //Servo control
sketch_mar25a:12:9: error: expected constructor, destructor, or type conversion before '(' token
  pinMode(2,OUTPUT);  //Motor driver pin 1
sketch_mar25a:13:9: error: expected constructor, destructor, or type conversion before '(' token
  pinMode(3,OUTPUT);  //Motor driver pin 2
sketch_mar25a:14:9: error: expected constructor, destructor, or type conversion before '(' token
  pinMode(4,OUTPUT);  //Motor driver pin 3
sketch_mar25a:15:9: error: expected constructor, destructor, or type conversion before '(' token
  pinMode(5,OUTPUT);  //Motor driver pin 4
sketch_mar25a:16:9: error: expected constructor, destructor, or type conversion before '(' token
  pinMode(6,OUTPUT);  //Ultrasonic Trigger
sketch_mar25a:17:9: error: expected constructor, destructor, or type conversion before '(' token
  pinMode(7,INPUT);   //Ultrasonic Echo
sketch_mar25a:18:9: error: expected constructor, destructor, or type conversion before '(' token
  pinMode(8,OUTPUT);  //Laser
sketch_mar25a:19:9: error: expected constructor, destructor, or type conversion before '(' token
  pinMode(10,OUTPUT); //LED
sketch_mar25a:20:9: error: expected constructor, destructor, or type conversion before '(' token
  pinMode(A0, INPUT); //LDR
sketch_mar25a:21:2: error: 'laserstatus' does not name a type
  laserstatus="OFF";
sketch_mar25a:22:2: error: 'servoangle' does not name a type
  servoangle=90;
sketch_mar25a:23:2: error: 'myservo' does not name a type
  myservo.write(servoangle);
sketch_mar25a:24:2: error: 'recordstatus' does not name a type
  recordstatus="NotRecording";
sketch_mar25a:25:2: error: 'requiredrecordstatus' does not name a type
  requiredrecordstatus="StopRecording";
sketch_mar25a:26:2: error: 'fr' does not name a type
  fr=0;
sketch_mar25a:27:2: error: 'br' does not name a type
  br=0;
sketch_mar25a:28:2: error: 'sr' does not name a type
  sr=0;
sketch_mar25a:29:2: error: 'rr' does not name a type
  rr=0;
sketch_mar25a:30:2: error: 'lr' does not name a type
  lr=0;
sketch_mar25a:31:2: error: 'i' does not name a type
  i=0;
sketch_mar25a:32:2: error: expected unqualified-id before 'for'
  for(int c=0;c<20;c++)
sketch_mar25a:32:14: error: 'c' does not name a type
sketch_mar25a:32:19: error: 'c' does not name a type
sketch_mar25a:42:3: error: expected unqualified-id before ')' token
exit status 1
option enabled in File -> Preferences.
PaulS
Quote
Then the code you didn't post is NOT ALL CORRECT.
Where IS your code?
GypsumFantastic
Show us the sketch code. Remember to use [code][/code] tags.
david_2018
I would suspect something prior to the first error on line 10.  Probably a simple typing error or you left something off, like a bracket or semicolon.  Most of the other errors messages are just a consequence of the initial error.
neiklot
Look carefully at the line for setup which should be like this:
Code: [Select]
... or this:
Code: [Select]
It's complaining about it here:
Code: [Select]
... but I tried a few common mistakes and can't get your error, alas.
edit, or you may have an imperfectly formed include or define or something above setup().
