Topic: AD595AQ for Car Exhaust Gas Temperature (Read 10803 times) previous topic - next topic
matinzk
I have substituted them with one another the same thing.
Arduino uses the same L7809CV chip as the AD595AQ, and the L7809CV is connected to the chassis.
EmilyJane
By the "same thing" do you mean they both read wrong now or that just the one on the car reads wrong. What happens when you touch the "home" one to the car.
matinzk
EmilyJane
Oh, okay. Something happened to your circuit in transit apparently. You need to thoroughly check it for loose, broken wires, short circuits, etc. Anything that is different from when it last worked correctly.
matinzk
It works fine when I don't connect it to the car, so the probe that's on the car, when removed and pin 1 connected to pin 4 it works fine!
So the chip is fine, isn't it?
Is it better to go and get an ungrounded probe then? And leave the circuit with pin 1 connected to pin 4?
Thanks.
EmilyJane
You could try that. Otherwise it's a mystery to me.
EmilyJane
By the way, why did you choose to run it off 9V? That part works on 5V.
matinzk
I needed temperature of more than 300'C so I increased the input voltage.
EmilyJane
matinzk
No I haven't, but does that solve my grounding problem?
Thanks.
EmilyJane
No, only in the sense that it might correct the problem that we haven't been able to sleuth out yet. Plus I just like the fact that it has a digital interface so it leaves out some steps in processing the data.
Without looking at your project, I'm at a standstill. Can you post the EXACT schematic diagram and some closeup photos of all sides of your physical circuit?
matinzk
I got an ungrounded thermocouple and everything is working normally now.
Thanks for all the help.
EmilyJane
