Topic: Life Clock (Read 17683 times) previous topic - next topic
florinc
Thanks for the X10 link. Total news to me. (I already have an X10 receiver that I use, so I am half way there already :)
That's right, a screw-in light fixture, like a light bulb. I think the glass dome I mentioned earlier will fit well in here, but used upside down (with the wooden base part on top, and a light bulb screw attached to it). We would need to find a way to secure the dome to the wooden base. A small power adapter (the "USB wall wart") should fit in the dome as well. I am thinking that even a glass jar can be adapted for the job, and it would be easier to attach the screw to the metal lid.
A servo will be required to rotate the display (to position it for the best viewing).
Also, a set of high intensity LEDs could be installed opposite to the display matrix, and used as directed, remote-controlable, light source. (now that this Arduino contraption is screwed where the old light fixture was).
I see a few challenges that need to be resolved:
- mic and buzzer are inside the jar/dome/bulb now;
- IR receiver should be reachable by remote even when the whole thing is rotated 180 degrees and not facing the remote (can you have 2 IR receivers in parallel?);
And, listen to this: if an accelerometer is included (or some positioning sensor), then the contraption can be screwed up in the ceiling (hanging down) or screwed down in a desk lamp, and the display will still show the text in the correct stance.
What do you think?
florinc
A bit of an update on the slow progress of my version of "Life Clock" (I could not resist  :-[):
- I switched to atmega 328, $2 more expensive, but lots of memory for future expansions;
- I was able to store my character set definition (8 bytes per character x 96 characters) in the local eprom (1K now); so now the 24LC256 eprom has only messages (32K, aprox 16 book pages);
- implemented "sleep mode", through remote control; in sleep mode, the whole thing is taking now 3.5 mA (an off-the-shelf arduino takes at least 15 mA in sleep mode). For this purpose, I had to build a custom arduino board, basically a protoshield (the small/short version) with only the processor on it. I eliminated the power LED (20 mA wasted right there), the FTDI chip, and the voltage regulator and the reset button (I always use a shield that has a reset button).
- I am still waiting for the LED matrix shields from seeedstudio; they should be available for everyone soon;
I think there would be a need for yet another arduino-compatible board, one similar to Arduino Pro from sparkfun, but with an atmega 328 on it and no LEDs, plus some other provisions for sleep mode.
NVRDUNN
BroHogan,
Could you send me a copy of the schematics and code? I'm really interested in the code for loading and reading the eeprom for font data. I'm looking at making a sign, but the main part i'm hung up on is the way to take a message and lookup the font data in eeprom. Nice project!  :)
florinc
#18
Feb 20, 2009, 03:24 am Last Edit: Feb 20, 2009, 01:38 pm by florinc Reason: 1
More progress! Today I received the shields from seeedstudio. Everything worked like a charm, no glitches, no surprises, almost unbelievable!
This is how it looks like:
More photos here:
http://flickr.com/photos/11567579@N05/3293540285/in/set-72157612254405335/
I added a (poor quality unedited) video as well:
http://www.youtube.com/watch?v=PEtojxk4Cpg
boerner
That looks amazing. Great work. I just posted the other day asking for an update on the RainbowDuino http://www.seeedstudio.com/blog/?page_id=187
Can I assume that you are using what will be that product?
florinc
Thanks.
I reckoned that using a glass dome would be suitable for a clock. Plus, being transparent, it gives access to the IR receiver.
No, I did not use the seedstudio's RainbowDuino. I designed my own and I got it manufactured by them. (My previous posting has a link to the photo of the little black board, the LED matrix shield).
I can provide more hardware details if you are interested.
boerner
Yes, more details please!  :)
Did they do this for you as a one-off, or are they going to manufacture your design?
florinc
#22
Feb 21, 2009, 10:16 pm Last Edit: Feb 21, 2009, 10:18 pm by florinc Reason: 1
Seeedstudio offers this so called "Propaganda PCB service" , check it out at http://www.seeedstudio.com/forge/wikka.php?wakka=Propaganda.
You email them the Eagle board file (must be open source) and they send you 5 boards for $30.
I had the shield for the 8x8 RG LED matrix made by them.
Theoretically, you should be able to buy the boards I designed from their website, although I did not see them posted yet. Just ask. Anyway, I just finished revision 1.1 and I will get it manufactured in bigger batch.
As for the arduino, I used one made on the small prototype shield, since I wanted all the boards in the sandwich to have the same dimensions, and also because I wanted to eliminate some components (from the original arduino) that I did not need and which took some juice out of the batteries. I almost finished the design of this board (waiting to get a few more components). This should be also available soon.
After much thinking, I came to realize that Mr. BroHogan's original "sandwichduino" is the best approach for this kind of project. And coming up with a case is as challenging. The glass dome I used is not cheap, but the cherry case required even more effort, I assume.
The project is still in development, since I plan to add a few more things, as suggested in previous postings here.
florinc
Here is a new version of the clock project:
The idea was to be hung on a wall. I had a few options for the case, but they would require some fine work and skills, so I opted for the easiest and quickest, a bent piece of plexiglass (clear acrylic).
The circuitry fits on one custom board. It should have been black, but I forgot to ask when I ordered it.
florinc
#24
May 12, 2009, 04:37 am Last Edit: May 13, 2009, 02:47 am by florinc Reason: 1
My friends asked for a larger display. Using the same LED driver circuitry, I replaced the bi-color 8x8 LED matrix with two, single color (red), 8x8 LED matrices. The result is shown below.
(The case, bought from a photo shop, was designed for storing 4x6 photos. It has a hinged glass door, held in place with small magnets. It can be also hung on the wall (this has become an obsession, it seems :'())
k2pek2
wow, i'm impressed. I like how your project got increasingly more complicated!
as a sidenote... any figures in terms of total cost?
zooto68
The good thing about using 74HC595 is the price. The bad thing is that most of the digital outputs are used, there is no room for other add-ins like an ethernet card
Not sure what you mean by that. You only need 3 pins to drive 74HC595's.
florinc
Mike,
My approach uses a combination of 595 (2 pieces) and direct outputs, as shown in the schematic here:
http://www.flickr.com/photos/11567579@N05/3178651230/in/set-72157612254405335/
I could have used a third 595 to drive the rows and save some 5 outputs.
Since I dropped some "requirements", there are still 3 analog/digital pins available (for alarm/buzzer/x10, for example).
As for the input pins, I only need to use two: one is for IR receiver, one for a redundant push button. I am trying to funnel every user input through the remote control, including setting the time and the alarm.
Regarding the cost: the parts, PCB included, would run between US$60 (digikey) and $75 (sparkfun).
zooto68
I see. Nice project by the way.
