Topic: Error when trying to Bootload a ATMega328P-PU (Read 1 time) previous topic - next topic
Ash4004
I am trying to take the ATMega and build it into a custom circuit.  I have used a protoboard and everything works fine, now I want to take the Micro Controller off the Arduino and install it directly onto the Breadboard.  I am following this tutorial, http://arduino.cc/en/Tutorial/ArduinoToBreadboard with the Minimal Circuit method.  I can not get the bootloader to load.  I have the right hardware selected, I have checked my wiring.  I have been searching the forums but can not find and good answers.  Has anyone been able to solve this problem?
Quote
Error While Burning Bootloader
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
One thing that I am questioning is does  a Microcontroller need to be installed when loading the bootloader?  And if so can I use a SMD Edition to do it?  I get the same error weather I use the Arduino Uno that I took the chip from and when I use the SMD Edition.  I don't get that.
cyclegadget
This thread may help you. http://arduino.cc/forum/index.php/topic,61776.0.html
If you agree bump it by putting a comment in it.
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
Ash4004
Thanks cyclegadget.  That seems like a good tutorial, the only problem is I don't have the necessary components.  I can order them, but I am making a present for my friend and I am afraid that if I wait for them to be shipped I won't have enough time.
Has anyone had success using the minimal settings?  If so how did you do it?
