Loading...
Pages: [1]   Go Down
Author Topic: rs232 rfid reader to arduino uno  (Read 1064 times)
Offline Offline
Newbie
View Profile
The output of my RFID reader is rs232 and im currently using a rs232-ttl converter to connect it to my arduino MCU.(http://www.lipoly.de/index.php?main_page=product_info&cPath=880_2612_2669&products_id=163671). I currently cant get any output . Im using a simple code where the LED will blink and it will print "receive" on the serial monitor when there is data coming in. (codes shown below). when i scan the card on the RFID reader, the LED on the arduino wont blink and when i open the serial monitor, i wont get the message "received". Do i have to initialize the RFID reader or some sort? or am i connecting it wronly?  The TXD from the rs232-ttl is connected to pin 2 while the RXD from the rs232-ttl device is connected to pin 3 of the arduino ( i have tried connecting them in the other fashion) , the ground and vcc are connected to the arduino accordingly as well.
The RFID im using is this one:  http://www.rfidshop.com.hk/datasheet/UHF-Reader/CD-UHF-MP-RW-232.zip
Thanks ,
Jason
#include <SoftwareSerial.h>
#define rxPin 2
#define txPin 3
#define ledPin 13
// set up a new serial port
SoftwareSerial mySerial =  SoftwareSerial(rxPin, txPin);
void setup()  {
  // define pin modes for tx, rx, led pins:
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
   if (Serial.available() > 0) {
  // listen for new serial coming in:
  char someChar = mySerial.read();
   Serial.print("received: ");
  digitalWrite(13, HIGH);   // set the LED on
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // set the LED off
Logged
New Jersey
Offline Offline
Edison Member
View Profile
Not that this is the issue, but you'll need a serial.begin in setup as well.
Logged
Pages: [1]   Go Up
Print
Jump to:
