Loading...
Pages: [1]   Go Down
Author Topic: *SOLVED* Using my Arduino's logic to now control the motor  (Read 545 times)
Offline Offline
Newbie
View Profile
Hi. This is a recovery of this old thread I started here: http://arduino.cc/forum/index.php/topic,72791.msg545937.html#msg545937
However, I now would like to learn how to use my Arduino to control the motor, rather than using a switch, such as the way mentioned here: http://arduino.cc/playground/Main/DCMotorControl
Would anyone like to share how it works?
It says the schematic is wrong. So I dont know.
I believe the Arduino would trigger the transistor (HIGH), and the transistor would then trigger the relay.
I can share my current schematic should you need it to help me out.
All I need is to replace my switch (turns the motor on and off), and replace my other switch that sets the motors direction with digital logic.
From there, I can figure things out to finish my slot loading drive smiley
Thank you.
« Last Edit: April 07, 2012, 12:14:02 am by Haunted360 » Logged
Offline Offline
Newbie
View Profile
SOLVED
I just was not thinking right and I had the pinstate set as an OUTPUT still smiley-roll-blue
Logged
Pages: [1]   Go Up
Print
Jump to:
