Loading...
Pages: [1] 2   Go Down
Author Topic: Sonar and MIDI Mapping  (Read 790 times)
Newcastle Upon Tyne
Offline Offline
Newbie
Studying Interactive Media Design at Northumbria University's School of Design.
View Profile
WWW
Hi
I have a LV-MaxSonar EZ1 and I using this code to get readouts of distance measurements.  This is the code that I am using for that:
Code:
//Feel free to use this code.
//Please be respectful by acknowledging the author in the code if you use or modify it.
//Author: Bruce Allen
//Date: 23/07/09
//Digital pin 7 for reading in the pulse width from the MaxSonar device.
//This variable is a constant because the pin will not change throughout execution of this code.
const int pwPin = 7;
//variables needed to store values
long pulse, inches, cm;
  //This opens up a serial connection to shoot the results back to the PC console
  pinMode(pwPin, INPUT);
    //Used to read in the pulse that is being sent by the MaxSonar device.
  //Pulse Width representation with a scale factor of 147 uS per Inch.
  pulse = pulseIn(pwPin, HIGH);
  //147uS per inch
  inches = pulse/147;
  //change inches to centimetres
  cm = inches * 2.54;
  Serial.print(inches);
  Serial.print("in, ");
  Serial.print(cm);
  Serial.print("cm");
I have a potentiometer that sends MIDI data over a DIN-5 MIDI connector attached to my breadboard using this code:
Code:
 * 7.1 Midi OUT controller
 * roguescience.org
 * digital pin 11 (OUTPUT/PWM) --> LED
 * digital pin 2 (INPUT) <-- button
 * analog pin 0 <-- pot
 * tx1 <-- pin 5 (5 PIN DIN aka MIDI jack)
 * Send a MIDI note when the button is pressed and sends MIDI
 * CC data when a potentiometer is turned.
int ledPin = 11;                //choose the pin for the LED - needs to be (3,5,6,9,10, or 11)
int buttonPin = 2;               //choose the input pin for a pushbutton
int potPin = 0;                  //choose the input pin for a potentometer
int buttonVal = 0;                    //variable for reading the button status
int buttonState = 0;            //variable to hold the buttons current state
int bounceCheck = 0;            //variable for debouncing
int potVal = 0;                //variable for reading potentiometer value
int mappedPotVal = 0;          //variable for holding remapped pot value
int prevPotVal = 0;               //variable for storing our prev pot value
int THRESHOLD = 2;            //threshold amount
  pinMode(ledPin, OUTPUT);      //declare LED as output
  pinMode(buttonPin, INPUT);     //declare pushbutton as input
  Serial.begin(31250);            //MIDI communicates at 31250 baud
void loop(){
  buttonVal = digitalRead(buttonPin);     //read input value from button
  delay(10);                              //wait 10ms
  bounceCheck = digitalRead(buttonPin);   //check again
  if(buttonVal == bounceCheck){           //if val is the same then not a bounce
    if (buttonVal == HIGH && buttonState == 1) {   //check if the input is HIGH
      digitalWrite(ledPin, LOW);         //turn LED OFF
      midiOUT(0x90, 60, 0); //Note ON (CH 1), middle C, zero velocity turns note off
      buttonState = 0;
    if(buttonVal == LOW && buttonState == 0){
      digitalWrite(ledPin, HIGH);       //turn LED ON
      midiOUT(0x90, 60, 127); //Note ON (CH 1), middle C, velocity 127
      buttonState = 1;
   potVal = analogRead(potPin);         //read input from potentiometer
   mappedPotVal = map(potVal, 0, 1023, 0, 127);  //map value to 0-127
   if(abs(mappedPotVal - prevPotVal) >= THRESHOLD){
     midiOUT(0xB0, 7, mappedPotVal); //Control Change (Ch 1), Controller 7 - default control for volume.
     prevPotVal = mappedPotVal;
   else{
void midiOUT(char command, char value1, char value2) {
  Serial.print(command, BYTE);
  Serial.print(value1, BYTE);
  Serial.print(value2, BYTE);
The Sonar is inputting values over Pulse Width, whereas the Pot in the MIDI example is inputting values through an Analog pin.
What code will I need to replace the Analog Potentiometer with a Sonar input over Pulse Width?
Thanks
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
Code:
Here, potVal is a number that relates to the position of the pot wiper.
Code:
Here, pulse is a number that relates to the distance to whatever the ping sensor is seeing.
Code:
Here, the potVal is mapped to a range of 0-127.
You need something like
Code:
   mappedPulse = map(pulse, start, end, 0, 127);  //map value to 0-127
You will need to work out the start and end of the range of numbers that the ping sensor returns. I don't have one, so I don't know.
PS. Please don't cross post. If you didn't understand what I posted on http://arduino.cc/forum/index.php/topic,99709.msg748238.html, you could have said so, and I, or someone else, would have expanded on it.
Logged
Newcastle Upon Tyne
Offline Offline
Newbie
View Profile
WWW
Sorry for reposting something similar.  How would I find out the range?
Thanks
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
Write a simple sketch to print raw readings.
Point the sensor at the sky.
Point the sensor at something really close.
Point the sensor at the limits of detection.
Note the values.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Newcastle Upon Tyne
Offline Offline
Newbie
View Profile
WWW
I'm really sorry for being new to this, but how would I write a sketch to print raw readings?
Thanks
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
You already have one that converts the raw value to inches and centimetres. One of those options will probably be suitable.
Logged
Newcastle Upon Tyne
Offline Offline
Newbie
View Profile
WWW
Code:
  //147uS per inch
  inches = pulse/147;
  cm = inches * 2.54;
  Serial.print(cm);
  Serial.print("cm");
If I change that code above to this:
Code:
  Serial.print(pulse);
Will that give me raw readouts?
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
Yes, it would.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Yes, and you could make the first print a println, and skip the second completely.
Logged
Newcastle Upon Tyne
Offline Offline
Newbie
View Profile
WWW
What does 'println' do?  Can you explain it in layman's terms please?
Thanks
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
http://arduino.cc/en/Serial/Println
Logged
Newcastle Upon Tyne
Offline Offline
Newbie
View Profile
WWW
I have started again with this project starting from this: http://arduino.cc/en/Tutorial/Midi
I can get raw values from the MaxBotix sonar using this code:
Code:
//Date: 23/07/09
  //Pulse Width representation with a scale factor of 147 uS (microseconds) per Inch.
  Serial.println(pulse);
I am trying to change get the raw values to map to the range 0-127 so the distance measurement can act as a note.
I have put this code together, but it does not work:
Code:
//Date: 23/07/09
byte note = 0;            // The MIDI note value to be played
long pulse;
  mappedPulse = map(pulse, 827, 15000, 0, 127);  //map value to 0-127
 //  plays a MIDI note.  Doesn't check to see that
 //  cmd is greater than 127, or that data values are  less than 127:
 void noteOn(byte cmd, byte data1, byte data2) {
   Serial.write( byte(cmd) );
   Serial.write( byte(data1) );
   Serial.write( byte(data2) );
Can someone PLEASE help me write it!! smiley
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Once you have a mapped value, don't you think you should call noteOn()?
Logged
Newcastle Upon Tyne
Offline Offline
Newbie
View Profile
WWW
I keep getting the error:
Code:
Final_MIDI2.cpp: In function 'void loop()':
Final_MIDI2:32: error: 'mappedPulse' was not declared in this scope
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Where do you actually define a type for mappedPulse?
Logged
Pages: [1] 2   Go Up
Print
Jump to:
