Topic: Arduino on a breadboard ISP header (Read 1 time) previous topic - next topic
ekerin
I just got back my boards for an ISP programming helper for doing Arduino on a breadboard.  It is designed to sit over top of the ATmega168/328 in a breadboard and provides the 6-pin programming header.  In addition, it has the Arduino pin mapping information on the silkscreen to ease wiring.
Some obvious extensions I can think of are adding the non-pop pads for a ceramic resonator to the bottom side, and possibly the reset line.  They'd have to be SMT, since there isn't really any more room on the top side when a shrouded connector is populated.
Thoughts?
CrossRoads
Make the board wider? Then will have plenty of room for crystal, caps, reset pullup resistor, Vcc decoupling caps.
Osgeld
#2
Apr 07, 2012, 09:00 am Last Edit: Apr 07, 2012, 09:02 am by Osgeld Reason: 1
I just use micro clips that grab the leads(with no issues upto tsop),  and a bit of ribbon cable
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
april.steel
I dont see the point of this
All that work and expense when its just as easy to connect it direct to the pins?
JChristensen
I did something similar only different XD ... a pair of small boards that hang off the sides of the breadboard:
http://adventuresinarduinoland.blogspot.com/2011/09/arduino-breadboard-helpers.html
ekerin
I mainly did it to save time setting things up ( I only get about 2 hours a week to work on projects).  If I don't have to think about where the pins go or place them, I have more time to play.
My original board was all made from stuff I already had,  but I still had to continually reference the Arduino pin mapping.  So I designed the board during time I couldn't work on other projects ( long story, but designing simple PCBs really helps take my mind off things).  W/batchpcb's cost model, these only cost about $2.5 per when combined with something you were ordering anyway.
Oh nice!  As a separate thing, I have a board off the side w/ just the crystal and capacitor.  Yours is much nicer than that!
