Author Topic: Where to get 4-digit 7-segment LED with decimal points and colon 0.56" digits?  (Read 831 times)
Central MN, USA
Online Online
I have a design that needs  4-digit 7-segment LED with decimal points and colon 0.56" digits. I looked on ebay and there seems to be only 2 sellers that sell these (yeah, some are aliases of the same sellers). One has the wrong connection diagram. I got a sample from them and the decimal points don't work. The other seller doesn't even offer connection diagram and just claims all the dots work. Should I trust them? I also looked at digikey and sparkfun but they don't have large enough digits. If you have used such display (both decimals and colons have to work), can you suggest a source of this display? Thanks.
My only one suggestion received from GoForSmoke:
http://www.futurlec.com/LED/7FR5643AS.shtml
This is common cathode and there's only one color so I wonder if there are other ones and common anode ones out there I just don't know. Thanks.
These ones look pretty close:
http://www.sparkfun.com/products/9482
Central MN, USA
Online Online
Just a bit small. I will have to use them if I can't find the larger ones.
Grand Blanc, MI, USA
"We're a proud service of the Lost Electricity Reclamation Agency"
Pretty hard to find the colons, I've spent more than a little time looking myself. Tayda sells some that are visually almost identical to those that Sparkfun sells, but the connection is just a bit different, and they're common cathode. But like the Sparkfun displays, they are 0.4". Both are good quality displays, very crisp and they don't need a lot of current.
I'd really like to find a part with six digits or more so I could have 88:88:88, etc., but they just don't seem to be out there. A two-digit part with a colon would also work by stacking them.
Let us know if you turn anything up.
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Central MN, USA
Online Online
Will do. If I find anything useful, I'll post where I get them.
these http://www.taydaelectronics.com/led-displays/led-display-7-segment-4-digit-0-56-inch-common-anode-ultra-red-21937ucd.html might fit what you need.
www.rocketscream.com
http://www.satistronics.com/10pcs-056-inch-four-digital-led-display_p1477.html
Can select common cathode or anode too when purchase. But only red.
Boston area, metrowest
Check out kingbright LEDs.
http://www.kingbrightusa.com/category.asp?catalog%5Fname=LED&category%5Fname=KC4%2DDigit+0%2E56in&Page=1
Whole series of common anode, common cathode, different colors.
