Loading...
Pages: 1 [2]   Go Down
Author Topic: Ethernet Shield with index.htm SDcard.  (Read 6045 times)
Offline Offline
Newbie
View Profile
Thank you for your attention but I will not answer anymore, because did not understand my last post, and use the google translator did not help.
Forget the part of the SD, just want to know why when I type ip: 6969 on another computer it does not appear to me that:
http://imageshack.us/photo/my-images/525/controlcz.jpg/
but this:
http://imageshack.us/photo/my-images/29/principals.jpg/
I'm not mad at you, I'm just frustrated because he could not make them understand
Logged
Miramar Beach, Florida
Offline Offline
Faraday Member
View Profile
You don't have to answer. If you manage to get by the hardware problem, then I would suspect this comparison:
Code:
        if(readString.trim() == ("GET /?C=1678 HTTP/1.1")){
          //client.println("<h1>Clave Ok</h1>");
          Portada();
       }else{
          //client.println("<h1>Clave Erronea</h1>");
Just talking out loud here. I would try this instead. But that is just me.
Code:
        if(strcmp(readString.trim(), "GET /?C=1678 HTTP/1.1") == 0) {
          Portada();
       }else{
Logged
Offline Offline
Newbie
View Profile
Code:
          Portada();
       }else{
Code:
          Portada();
       }else{
i try this but gives errores
Code:
          Portada();
       }else{
look:
http://www.freeimagehosting.net/qap5b
« Last Edit: April 15, 2012, 10:55:31 am by rodolfovieira » Logged
Offline Offline
Faraday Member
View Profile
Now we are going places!
I don't use String types, and this (among other reasons) is why. I use character arrays.
Code:
char readString[20];
If you pass readString as a parameter now, it will work. At least it should. I have not used the .trim() function before, but now I might try it.
You will probably need to redo your ad-a-character routine to that array. Like this:
Code:
int charCount;
// Then in the loop
charCount = 0;
readString[0] = 0;
while(client.available())
   char c = client.read();
   if(charCount < 19)
      // store character
      readString[charCount] = c;
      charCount++;
      // set terminating zero
      readString[charCount] = 0;
// If you need to empty the array,
charCount = 0;
readString[0] = 0;
edit: I added the readString zero terminator when I set charCount to zero.
« Last Edit: April 15, 2012, 11:14:57 am by SurferTim » Logged
Offline Offline
Newbie
View Profile
hummmm this is something very difficult for me.
Do all you can send me the sketch already modified?
Or is abusing your generosity?
I do not know programming, these codes have been taking and adapting.
Thanks again
Logged
Offline Offline
Faraday Member
View Profile
Take a look here. Reply #3 has a web server with two form fields.
http://arduino.cc/forum/index.php/topic,94861.0.html
Bear in mind that sketch is IDE v1.0 and better to compile.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
