Topic: Ethernet Shield with index.htm SDcard. (Read 16379 times) previous topic - next topic
rodolfovieira
I found this code which is capable of storing an index.htm file on the SD card's ethernet shield.
I managed to make the point to open the index.htm was this:
Now what I wanted to do was change the code so that when I clicked on  image,  that TURN a one LED,and when i click again  Turn OFF led.
And anyone able to modify this code?
ARDUINO CODE
* This is a web server that allows you to host a fully functional html
*  webpage on the World Wide Web.
* Initial coding was done with the help from the many people in the Arduino community.
*  Thanks guys!!
* Arduino Setup: You need an Ethernet Shield SD, and and Arduino.
*  Optionally pins 8 and 9 can be used for two LEDs that can indicate traffic.
* SD Card Setup: On the SD card, which must be formated as fat, you must have
*  an HTML file with the file name of 'index.htm'. All file names on this card
*  must be written in the old 8.3 file format. In other words, all files must be
*  named with no more then 8 characters for the name, and 3 for the extension.
* Note: If you don't know HTML, a good place that I found useful was w3schools
*  http://www.w3schools.com/html/html_examples.asp
#include <LiquidCrystal.h>
#include <SPI.h>
#include <SdFat.h>
#include <SdFatUtil.h>
#include <Ethernet.h>
#define BUFSIZ 128
#define greenLEDandBEEP 2
#define redLEDpin 3
boolean led2 = true;
int hits = 0; // Set the number of hits the hit counter will start at.
int units = 0;
int count = 0;
int photocellPin = 2;
int photocellReading;
LiquidCrystal lcd(4, 5, 6, 7, 8, 9);
//Local ethernet setup
byte mac[] = {
  0x90, 0xA2, 0xDA, 0x00, 0x1C, 0x0E };
byte ip[] = {
  192, 168, 1, 80 };
char rootFileName[] = "index.htm";
Server server(8080);
//SD card stuff
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
#define error(s) error_P(PSTR(s))
void error_P(const char* str) {
  PgmPrint("error: ");
  SerialPrintln_P(str);
  if (card.errorCode()) {
    PgmPrint("SD error: ");
    Serial.print(card.errorCode(), HEX);
    Serial.print(',');
    Serial.println(card.errorData(), HEX);
  while(1);
  lcd.begin(16, 2);
  lcd.print("Web Server v2.00");
  lcd.setCursor(0, 1);
  lcd.print("Hits:");
  pinMode(greenLEDandBEEP, OUTPUT);
  pinMode(redLEDpin, OUTPUT);
  PgmPrint("Free RAM: ");
  Serial.println(FreeRam());
  pinMode(10, OUTPUT);
  digitalWrite(10, HIGH);
  if (!card.init(SPI_HALF_SPEED, 4)) error("card.init failed!");
  if (!volume.init(&card)) error("vol.init failed!");
  PgmPrint("Volume is FAT");
  Serial.println(volume.fatType(),DEC);
  Serial.println();
  if (!root.openRoot(&volume)) error("openRoot failed");
  PgmPrintln("Files found in root:");
  root.ls(LS_DATE | LS_SIZE);
  Serial.println();
  PgmPrintln("Files found in all dirs:");
  root.ls(LS_R);
  Serial.println();
  PgmPrintln("Done");
  Ethernet.begin(mac, ip);
  server.begin();
  if(count >=500)
    led2 = !led2;
    digitalWrite(redLEDpin, led2);
    count = 0;
  count +=1;
  char clientline[BUFSIZ];
  char *filename;
  int image = 0;
  int index = 0;
  Client client = server.available();
  if (client) {
    boolean current_line_is_blank = true;
    index = 0;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if (c != '\n' && c != '\r') {
          clientline[index] = c;
          index++;
          if (index >= BUFSIZ)
            index = BUFSIZ -1;
          continue;
        clientline[index] = 0;
        filename = 0;
        Serial.println(clientline);
        if (strstr(clientline, "GET / ") != 0) {
          filename = rootFileName;
        if (strstr(clientline, "GET /") != 0) {
          if (!filename) filename = clientline + 5;
          (strstr(clientline, " HTTP"))[0] = 0;
          Serial.println(filename);
          if (! file.open(&root, filename, O_READ)) {
            client.println("HTTP/1.1 404 Not Found");
            client.println();
            client.println("<h2>Error 404</h2>");
            client.println("<s2>The file does not exist.<s2>");
            client.println("");
            break;
          Serial.println("Opened!");
          //File types
          if (strstr(filename, ".htm") != 0)
          else if (strstr(filename, ".css") != 0)
            client.println("Content-Type: text/css");
          else if (strstr(filename, ".png") != 0)
            client.println("Content-Type: image/png");
          else if (strstr(filename, ".jpg") != 0)
            client.println("Content-Type: image/jpeg");
          else if (strstr(filename, ".gif") != 0)
            client.println("Content-Type: image/gif");
          else if (strstr(filename, ".3gp") != 0)
            client.println("Content-Type: video/mpeg");
          else if (strstr(filename, ".pdf") != 0)
            client.println("Content-Type: application/pdf");
          else if (strstr(filename, ".js") != 0)
            client.println("Content-Type: application/x-javascript");
          else if (strstr(filename, ".xml") != 0)
            client.println("Content-Type: application/xml");
            client.println("Content-Type: text");
          client.println();
          int16_t c;
          while ((c = file.read()) >= 0) {
            //Serial.print((char)c); //Prints all HTML code to serial (For debuging)
            client.print((char)c); //Prints all HTML code for web page
          //Hit counter math
          if(units >= 2)
            hits ++;
            units = 0;
          units +=1;
          //End hit counter math
          //Print the hit counters and light value
          lcd.setCursor(6, 1);
          lcd.print(hits); //Print hits for LCD hit counter
          client.print("<html><body>"); //HTML code starts here
          client.print("<P align=\"center\">");
          client.print("Hits since reset: <b>");
          client.print(hits); //Print hits to client
          client.print("</b><br>");
          photocellReading = analogRead(photocellPin);
          client.print("Light reading: ");
          client.print(photocellReading); //Prints light reading to client
          // A few threshholds
          if (photocellReading < 10) {
            client.print(" - Dark");
          else if (photocellReading < 200) {
            client.print(" - Dim");
          else if (photocellReading < 500) {
            client.print(" - Light");
          else if (photocellReading < 800) {
            client.print(" - Bright");
          else {
            client.print(" - Very bright");
          client.print("</p></body></html>"); //HTML code ends here
          //End hit counter and light value
          file.close();
        else {
          client.println();
          client.println("");
        break;
    digitalWrite(greenLEDandBEEP, HIGH);
    delay(1);
    digitalWrite(greenLEDandBEEP, LOW);
    client.stop();
//The End /*
INDEX.HTML CODE
<html>
<body>
<img src="w3schools.jpg" width="104" height="142" />
</body>
</html>
zoomkat
Some simple arduino server test code that controls the arduino pin 5 and a servo via web page buttons.
//zoomkat 3-17-12
//simple button GET server code to control servo and arduino pin 5
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
//Powering a servo from the arduino usually DOES NOT WORK.
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  //start Ethernet
  server.begin();
  myservo.write(90); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo co
  //enable serial data print
  Serial.println("server LED test 1.0"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE>Arduino GET test page</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<H1>Zoomkat's simple Arduino button</H1>");
          // DIY buttons
          client.println("<a href=\"/?on\"\">ON</a>");
          client.println("<a href=\"/?off\"\">OFF</a><br />");
          // mousedown buttons
          client.println("<br><input type=\"button\" value=\"ON\" onmousedown=\"location.href ('/?on');\"/>");
          client.println("<input type=\"button\" value=\"OFF\" onmousedown=\"location.href ('/?off');\"/>");
          // mousedown radio buttons
          client.println("<br><br><input type=\"radio\" value=\"ON\" onmousedown=\"location.href ('/?on');\"\">ON</>");
          client.println("<input type=\"radio\" value=\"OFF\" onmousedown=\"location.href ('/?off');\"\">OFF</>");
          client.println("</BODY>");
          client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf("on") >0)//checks for on
            myservo.write(40);
            digitalWrite(5, HIGH);    // set pin 4 high
            Serial.println("Led On");
          if(readString.indexOf("off") >0)//checks for off
            myservo.write(140);
            digitalWrite(5, LOW);    // set pin 4 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
rodolfovieira
i zoom, i glad to see you,
but i think you not understand my question.
On your project, the html is generate throught arduino,
but my case index.htm is open my SDCARD ethrnet shield and i have a Image, i want that when i click on Image , the image turn one led, and when i click again turn of the led.
sorry my english
zoomkat
The below has info on clickable images.
http://www.tizag.com/htmlT/htmlimagelinks.php
rodolfovieira
zoom thanks for reply, and your attention.
But i dont understand how can transform this code to be working whith my index.html
see.. my index.html code:
<html>
<body>
</body>
</html>
now, i want when click on w3schools.jpg...that turn led on pin3
and when click again turn led on pin3.
this is code i want tranform:
#include <SPI.h>
#include <SdFat.h>
#define BUFSIZ 128
#define redLEDpin 3
int units = 0;
int count = 0;
byte mac[] = {
byte ip[] = {
  192, 168, 1, 80 };
//SD card stuff
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
    Serial.print(',');
  while(1);
  lcd.begin(16, 2);
  lcd.print("Hits:");
  Serial.println();
  Serial.println();
  root.ls(LS_R);
  Serial.println();
  PgmPrintln("Done");
  server.begin();
  if(count >=500)
    led2 = !led2;
    count = 0;
  count +=1;
  char *filename;
  int image = 0;
  int index = 0;
  if (client) {
    index = 0;
          index++;
            index = BUFSIZ -1;
          continue;
        filename = 0;
            client.println();
            client.println("");
            break;
          //File types
          client.println();
          int16_t c;
          //Hit counter math
          if(units >= 2)
            hits ++;
            units = 0;
          units +=1;
          else {
          file.close();
        else {
          client.println();
          client.println("");
        break;
    delay(1);
    client.stop();
understand me?
zoomkat
Please go back to your previous post and modify them by high lighting the code and then click the # in the tool bar to put your code in a code box. Have you tried the below from the link I posted? The clickable image is an html thing, not arduino. In the arduino code, you probably need to use a toggle setup for the LED control.
<a href="http://www.espn.com" target="_blank">
<img src="ahman.gif" border="0"> </a>
zoomkat
If you want various clickable areas in a single image, the below has the info.
http://www.w3schools.com/tags/att_img_usemap.asp
http://www.w3schools.com/tags/tryit.asp?filename=tryhtml_areamap
rodolfovieira
What I want is simple, but you are not understanding.
I have this code, this code is doing is opening an index.html that is stored on the SD ethernet shield.
<html>
<body>
</body>
</html>
#include <SPI.h>
#include <SdFat.h>
#define BUFSIZ 128
#define redLEDpin 3
int units = 0;
int count = 0;
byte mac[] = {
byte ip[] = {
  192, 168, 1, 80 };
//SD card stuff
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
    Serial.print(',');
  while(1);
  lcd.begin(16, 2);
  lcd.print("Hits:");
  Serial.println();
  Serial.println();
  root.ls(LS_R);
  Serial.println();
  PgmPrintln("Done");
  server.begin();
  if(count >=500)
    led2 = !led2;
    count = 0;
  count +=1;
  char *filename;
  int image = 0;
  int index = 0;
  if (client) {
    index = 0;
          index++;
            index = BUFSIZ -1;
          continue;
        filename = 0;
            client.println();
            client.println("");
            break;
          //File types
          client.println();
          int16_t c;
          //Hit counter math
          if(units >= 2)
            hits ++;
            units = 0;
          units +=1;
          else {
          file.close();
        else {
          client.println();
          client.println("");
        break;
    delay(1);
    client.stop();
Now I do not know what the code I have to add to this that when I click on the image of my index.hml to connect the pin digitalWrite 7 and when you click the image again to connect the low digitalWrite pin7.
I do not want you Go take me examples of sites and links.
I want you to modify that code and send it to me, because I do not understand any of this.
thanks friends.
rodolfovieira
Viva, I managed to solve my problem.
Now only one point missing out ... I can not give and ask for help solving.
The code that is working and this:
# Include <Ethernet.h>
# Include <SPI.h>
    Simple Ethernet Test
Arduino server outputs simple text to browser
     The circuit:
     * Arduino Duemilanove
* Arduino Ethernet shield
* Basic FTDI 5V breakout
* LED connected to digital pin 4 and GND via resistor
Byte mac [] = {0x90, 0xA2, 0xDA, 0x00, 0x49, 0xD6};
IP Byte [] = {} 192,168,1,70 / / IP address of WiShield
Gateway Byte [] = {} 192,168,1,254 / / router or gateway IP address
Subnet Byte [] = {} 255,255,255,0;
Server server (6969) / / server port
LedPin Int = 4 / / LED pin
Int ledPin = 7;
String state = String (3);
Word Adc = 0;
ReadString String = String (30) / / string for fetching data from address
LEDON Boolean = false; / / LED status flag
Void Pasword ();
Carried Void ();
Void setup () {
  / / Start Ethernet
  Ethernet.begin (mac, IP, gateway, subnet);
  / / Set to output pin 4
  PinMode (ledPin, OUTPUT);
  DigitalWrite (ledPin, LOW);
  State = "OFF";
  / / Enable serial print dated
  Serial.begin (9600);
Void loop () {
  / / Create a client connection
  Client client = server.available ();
  If (client) {
    While (client.connected ()) {
      Char client.read c = ();
      If (readString.length () <30) {
         ReadString + = c;
      Serial.print (c);
      If (c == '\ n') {
        if (readString.trim () == ("GET /? C = 1678 HTTP/1.1")) {
          / / Client.println ("Clave <h1> Ok </ h1>");
          Carried ();
       Else {}
          / / Client.println ("erroneous <h1> Clave </ h1>");
       / / Client.println ("HTTP/1.1 200 OK");
       / / Client.println ("Content-Type: text / html");
       Client.println ();
       Client.print ("<body style=background-color:#ffffff>");
       Client.println ("Control de Acceso <h1> </ h1>");
       Client.println ("<form method=get name=LED>");
       Client.println ("<input type=""password"" name=C>");
       Client.println ("<input type=submit value=submit> </ form>");
       / / Read next string is clearing
       ReadString = "";
       / / Stopping client
       Client.stop ();
Void Homepage () {
While (1) {
If (client) {
    / / An http request ends with a blank line
    CurrentLineIsBlank Boolean = true;
      If (client.available ()) {
        / / If you've gotten to the end of the line (received a newline
        / / Character) and the line is blank, the http request has ended,
        / / So Can you send a reply
          ReadString.concat (c);
        If (c == '\ n' && currentLineIsBlank) {
          / / Send a standard http response header
          LED Int readString.indexOf = ("LED =");
          If (readString.substring (LED, +5) == '= LED T ") {
            DigitalWrite (ledPin, HIGH);
            State = "ON";
          Else if (readString.substring (LED, +5) == "LED = F") {
            State = "OFF";
          Client.println ();
          Client.println ("<form method=get name=form>");
          Client.println ("<img src = 'http://dl.dropbox.com/u/6916111/tvoff.png' style = \" position: fixed; left: 68px; top: 80px; width: 636px; height: 431px; z-index: 1; padding: 0; \ ">");
          If (state == "ON") {
       / / Client.print ("TEST");
          Client.println ("<img src = 'http://dl.dropbox.com/u/6916111/tvon.png' type =" image "style = \" position: fixed; left: 254px; top: 146px; width : 146px; height: 93px; z-index: 2; padding: 0; \ ">");
          Client.println ("<a href = \". /? LED = F \ "src = 'http://dl.dropbox.com/u/6916111/off.png' type =" image "style = \" position : fixed; left: 254px; top: 146px; width: 146px; height: 93px; z-index: 2; padding: 0; \ ">");
  else {
  client.println ("<img src = 'http://dl.dropbox.com/u/6916111/off.png' type =" image "style = \" position: fixed; left: 254px; top: 146px; width : 146px; height: 93px; z-index: 2; padding: 0; \ ">");
          client.println ("<a href = \". /? LED T = \ "src = 'http://dl.dropbox.com/u/6916111/tvon.png' type =" image "style = \" position : fixed; left: 254px; top: 146px; width: 146px; height: 93px; z-index: 2; padding: 0; \ ">");
          / / Client.print ("LED is");
         / / Client.print (state);
          client.print ("<br>");
          break;
        if (c == '\ n') {
          / / You're starting a new line
          currentLineIsBlank = true;
        else if (c! = '\ r') {
          / / You've gotten a character on the current line
          currentLineIsBlank = false;
    / / Give the web browser time to receive the data
    delay (1);
    ReadString = "";
    / / Close the connection:
    client.stop ();
what is happening is this:
how do I access my shield through the browser
it goes OK, and do what you have to do is:
Show a field where you put the password and then do a submit button and proceed to the main page.
Ate there all right.
What is bad is if I close the browser and return the ip of my shield in the browser, it does not already asking for the password but goes directly to the main page and I do not want it.
Thank you
SurferTim
Does that mean you have one sketch working and this sketch in addition? How much of this can you get to even compile, much less run:
Try the example sketch again.
rodolfovieira
sorry the code is:
#include <SPI.h>
     The circuit:
* Basic FTDI breakout 5V
*LED connected to GND and digital pin 4 via resistor
By Minde
     http://www.sciencprog.com/
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x49, 0xD6 };
byte ip[]    = {192,168,1,70}; // IP address of WiShield
byte gateway[]  = {192,168,1,254}; // router or gateway IP address
byte subnet[] = {255,255,255,0};
Server server(6969);        //server port
int ledPin = 4;  // LED pin
int LEDpin = 7;
String state = String(3);
word Adc = 0;
String readString = String(30); //string for fetching data from address
boolean LEDON = false; //LED status flag
void Pasword();
void Portada();
void setup(){
  //start Ethernet
  //Set pin 4 to output
  pinMode(LEDpin,OUTPUT);
  digitalWrite(LEDpin,LOW);
  state = "OFF";
  //enable serial datada print
void loop(){
  if (client) {
    while (client.connected()){
      if (readString.length() < 30){
         readString += c;
      Serial.print(c);
      if (c == '\n') {
        if(readString.trim() == ("GET /?C=1678 HTTP/1.1")){
          //client.println("<h1>Clave Ok</h1>");
          Portada();
       }else{
          //client.println("<h1>Clave Erronea</h1>");
       //client.println("HTTP/1.1 200 OK");
       //client.println("Content-Type: text/html");
       client.println();
       client.print("<body style=background-color:#ffffff>");
       client.println("<h1>Control de Acceso</h1>");
       client.println("<form method=get name=LED>");
       client.println("<input type=""password"" name=C>");
       client.println("<input type=submit value=submit></form>");
       readString="";
       //stopping client
       client.stop();
void Portada(){
while(1){
if (client) {
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (readString.length() < 30) {
          readString.concat(c);
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          int LED = readString.indexOf("LED=");
          if (readString.substring(LED,LED+5) == "LED=T") {
            digitalWrite(LEDpin,HIGH);
            state = "ON";
          else if (readString.substring(LED,LED+5) == "LED=F") {
            state = "OFF";
          client.println();
          client.println("<form  method=get name=form>");
          client.println("<img src='http://dl.dropbox.com/u/6916111/tvoff.png' style=\"position:fixed;left:68px;top:80px;width:636px;height:431px;z-index:1;padding:0;\">");
          if (state == "ON") {
       //   client.print("TESTE ");
          client.println("<img src='http://dl.dropbox.com/u/6916111/tvon.png' type='image' style=\"position:fixed;left:254px;top:146px;width:146px;height:93px;z-index:2;padding:0;\">");
          client.println("<a href=\"./?LED=F\" src='http://dl.dropbox.com/u/6916111/off.png' type='image' style=\"position:fixed;left:254px;top:146px;width:146px;height:93px;z-index:2;padding:0;\">");
else {
client.println("<img src='http://dl.dropbox.com/u/6916111/off.png' type='image' style=\"position:fixed;left:254px;top:146px;width:146px;height:93px;z-index:2;padding:0;\">");
          client.println("<a href=\"./?LED=T\" src='http://dl.dropbox.com/u/6916111/tvon.png' type='image' style=\"position:fixed;left:254px;top:146px;width:146px;height:93px;z-index:2;padding:0;\">");
          //client.print("LED is ");
         // client.print(state);
          client.print("<br><br>");
          break;
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
    // give the web browser time to receive the data
    delay(1);
    readString = "";
    // close the connection:
    client.stop();
void Pasword();
SurferTim
#12
Apr 15, 2012, 04:12 pm Last Edit: Apr 15, 2012, 04:27 pm by SurferTim Reason: 1
There are a few conflicts here. You can't use digital pin 4 for anything but the SD SPI Slave Select. That pin is taken. When you set pin 4 LOW, you are enabling the SD SPI interface. Can't do that.
edit: You can do that, as you have proven, but you can't do that and use the SPI bus to communicate with the w5100.
Use the proper Ethernet.begin() format.
Ethernet.begin(mac, ip, dns, gateway, subnet);
// or if you do not use dns in your code, you can use the gateway for the dns server ip
Ethernet.begin(mac, ip, gateway, gateway, subnet);
edit: If you are using v0023 or older, the format should be
Ethernet.begin(mac, ip, subnet , gateway);
rodolfovieira
#13
Apr 15, 2012, 04:35 pm Last Edit: Apr 15, 2012, 04:38 pm by rodolfovieira Reason: 1
Sorry, but I think you do not understand what I said.
The code is all working beautifully.
The only thing that is happening is wrong:
When I type my ip: 6969 in browser it asks for the password:
http://imageshack.us/photo/my-images/525/controlcz.jpg/
after entering the correct password it will connect the main page:
http://imageshack.us/photo/my-images/29/principals.jpg/
Now what is wrong is if I close the browser, or attempt to access another computer to my ip: 6969 does not show new password to page:
but goes direct on the main page
Do you understand now? I want whenever you go to ip: 6969 it enters the password page.
SurferTim
(snip)
Do you understand now? (snip)
No, I don't. If it is working beautifully, why are we having this dialog?
You also did not understand what I said. You cannot use digital pin 4 for anything but the SD SPI bus Slave Select. Do you have a microSD card in the slot yet? When you do, if not already, this will cause problems.
