Author Topic: Fet or Bipolar junction transistor?  (Read 539 times)
Guys could you please answer me these?
>Whats the difference in use between a fet (ie mosfet) and a bipolar junction transistor (ie npn) ?
>I ve heard that fets are voltage controlled and that bipolars are current controlled. Am i correct on this? How would a bipolar react to higher voltage at the same current and how would a fet react to a higher current at the same voltage?
> When do i use an npn and when a pnp? I mean whats the great difference in use between them?
> How do i check out which is an npn and a pnp using a multimeter?
> Is there a way to know which one pin of the bipolar is which without the need to check for a datasheet? (ie turn the transistor facing its front side, the left pin is the collector, the right pin is the emitter  and the middle pin the base)
> Would anything change if the load was connected to the emitter instead of the collector?
Thanx in advance for the help and have a nice day smiley
Left Coast, CA (USA)
Measurement changes behavior
Those are a lot of questions and pretty hard to do justice to them in short replies. Why don't you just search out for some reference material on transistor semiconductor fundamentals, and learn the basics like most have? That would give you a lot more background and knowledge then just being feed answers to be memorized. None of your questions are dumb by any means, but they are better answered in context of learning the subject in my opinion.
Lefty
Thanx for the advice sir smiley
York, United Kingdom
If it's specifically transistors you want
http://www.amazon.co.uk/Transistor-Circuit-Techniques-integrated-Engineering/dp/0748740759/ref=sr_1_1?ie=UTF8&qid=1333925112&sr=8-1
This book has just about everything in it, and it is generally explained well.
Dean
Maryland, USA
Ok so as another newbie who's slowly picking up electronics at the age of 30, one of those things I always wanted to learn but never found the motivation/time... let me see if I can take a stab at this smiley-wink
1. BJT's are current-controlled indeed, the "control" current goes between the Base and Emitter, and it affects peak current allowed through the Collector-Emitter.
2. FETs are voltage-controlled, you could think of them as having a tiny capacitor sitting between the Gate and Source pins.  The charge of this capacitor affects the resistance of the Drain-Source link.
3. We'll group NPN bjt's and N-channel FETs together, and group PNP bjt's with P-channel FETs.
If you are using the transistor to switch power on/off to some load (often called "SATURATION MODE"), an NPN/N-channel is used as a "Low-side switch" meaning it switches on/off the negative (GND) side.  This is because the voltage applied to the base (or gate, in a FET) has to be positive relative to the emitter (or source in a FET), meaning the emitter or source needs to be a reliable connection to GND.  So for an NPN BJT, the load's connection to GND wouldn't go to ground directly, but pass through the collector (or drain, in a FET) first and you'd apply voltage to the base (or gate) to switch it on, and bring the base or gate to GND to switch it off.
PNP/P-channel is a "High-side switch", and the Emitter or Source has to be reliably connected to the + voltage supply, with the base or gate acting to switch the transistor on by getting pulled to GND.  It switches it off by making the base or gate the same voltage as the emitter or source, which is the same as the + voltage supply.  Consequently it could be thought of as "inverting" the logic; if you're using an Arduino pin attached to the gate of a P-channel MOSFET, source connected to the arduino's +5V power supply, drain connected to some fancy circuit of yours, switching the arduino's pin HIGH would turn it off (making the gate & source the same voltage, so the Vgs is 0V), turning it LOW would turn it on.
A reliable circuit that drives a BJT or FET typically involves resistors either between the Arduino's pin and the base (for a bjt) possibly with a pullup or pulldown resistor to "bias" the transistor's state when the arduino is shut off or hasn't switched its pin to output mode yet.  FETs usually have a pullup or pulldown resistor to implement a bias in the transistor's state.  Doesn't need to be a low value, something on the order of 10k-50k ohms, depends on how fast you need the transistor to switch.
I left out a ton of stuff and there's way more to learn, so definitely buy one of the available books and study up.  There's lots of use for transistors with amplification, adjusting voltage levels for analog signals/RF/etc where it uses the transistor in a state below the "saturation" point and implements fancy voltage dividers/etc to hold a signal somewhere in the "linear" region of operation.
But as simple on/off switches, they are very effective (and fast) if you buy the right one that can handle the voltage and current requirements for the circuit you're switching... Be very attentive when using PNP/P-channel transistors though, that you are not exposing the Arduino to the base (or gate) when the voltage at the emitter (or source) is too high for the arduino to handle (say >5.5V) as you could blow the processor.  Study up well before designing a circuit around one of these especially if it uses any voltages greater than 5.5V.
@spirilis
Thanx for the reply dear sir... and i am not 30...just turned 17 a week ago....i love electronics and this is a subject that highschool does not teach so i am self taught...again thank you
