Loading...
Pages: [1]   Go Down
Author Topic: Bug  (Read 752 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Bug
I'm not sure where this should go but I'm sure it's a bug.
In http://arduino.cc/en/Reference/StreamReadBytes readBytes is documented as taking either char[] or byte[] but when used with an SD File object you have to cast it to char[]. Hell it's called readBytes not readChars. Perversely enough an eithernet client wants bytes.
      This works but vice-versa fails
      byte bfr[outBfrSz];
      source.readBytes((char)bfr,outBfrSz);
      client->write(bfr,outBfrSz);
« Last Edit: April 08, 2012, 08:38:53 pm by TheNorm » Logged
Offline Offline
Newbie
View Profile
I noticed this too using the Serial.readBytes() function (which is inherited from the Stream library).  I didn't want to use chars because I don't want 0xff == -1.  I overloaded the Stream::readBytes() function in Stream.cpp and Stream.h to have a char * as well as a byte * version, and now it compiles happily using a byte array.
Logged
Pages: [1]   Go Up
Print
Jump to:
