Loading...
Pages: 1 [2]   Go Down
Author Topic: how to use 2 usb serial port at the same time on computer  (Read 1328 times)
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
i need some guide on the library
What library?
Quote
and the C# code
What C# code?
Logged
Offline Offline
Newbie
View Profile
Quote
What library?
Quote
and the C# code
What C# code?
mean if i use others IDE, then how i write the code for communicating between 2 com port?
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
It depends on what you use. Look at it's documentation for reading and writing serial data.
Logged
Offline Offline
Newbie
View Profile
ok thanks..i will look on that. if anything, i will post here and ask again. Thanks all of you for kindness replied. Thanks so much^^ smiley
Logged
Germany
Offline Offline
Edison Member
View Profile
I fear you're on a far too complicated path!
your link about the Evaluation Board - ADXL345 says
" The UART pins are also broken out allowing a direct TTL interface with the processor. "
You just need two digital pins and GND from the Arduino and connect that directly to the ADXL uart. (Rx to Tx , Tx to Rx, GND to GND)
Then look for the Arduino SoftwareSerial Library, and hopefully you see it's all done, already.
The next task is you probably need to see on the PC what's going on,
so you might like to copy the communication (both sides) to the standard serial.println to log it in the PC Arduino Serial Monitor.
Logged
Offline Offline
Newbie
View Profile
thanks for your advise. now honestly i have no exact idea on it. I try connect it with TX (from eval adxl board)to RX on arduino...i did print it on serial monitor but it seem llike displayed current value instead of the data i want....i am stuck on it now..
Logged
Offline Offline
Newbie
View Profile
can any one help me for using 4 uart ports of atmega 2560  at a time
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
What help do you need?
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
