Topic: 2 power supplies one breadboard (Read 964 times) previous topic - next topic
bobhawkens
I'm back for another awful newbie question. Thanks in advance for your patience.
I'm going to build my own arduino on a breadboard for an existing pure arduino project. My arduino sketch controls a motor and fan with an external 12v power supply and 2 transistors. Other sensors plug into the breadboard and then the arduino, which is powered by a 5v usb wall wart. I'm trying to combine everything.
Early on, when i knew even less than I do now, I tried to run everything with with the 12v into the vin jack. I fried an atmega that way. So I'm scared of all things power.
Is there a way to have one wall wart to send 5v to arduino and pins and 12v to motor and fan?
robtillaart
a 5V wall ward is too low for an Arduino according to specs... (7-20V ) The voltage will drop a bit due to the voltageregulator ....
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
bobhawkens
Ok, it's just a USB wall wart, so whatever voltage that is. The point is I want to use my 12v external to power fan and motor and arduino, but not mess up the listening sensors. Probably a dumb question but I'd love some resources to figure it out.
robtillaart
you can connect the 12 Volt to the power socket (so not to the Vin or the +5V pin).. The voltage regulator will handle it.
Rob Tillaart
bobhawkens
This will be a standalone atmega328 running as an arduino. So, what voltage regulator should I get? Also, will I branch out the positive pin from the 12v wall wart to the regulator AND the fan and motor? Thanks for your help.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
