Topic: Ethernet client and UDP together in same sketch (Read 2560 times) previous topic - next topic
flyaway
Hello
I'm trying to run Ethernet client to write data in a mysql server and read UDP to turn on/off functions on arduino.
I have already wrote 2 sketchs one for ethernet and one for UDP, they are running properly but when I try to join them in the same sketch, Udp doesn't run...
client sketch :
// mode client             //
// charge la page bdd.php  //
// avec la température en argument //
// FONCTIONNEL             //
#include <Ethernet.h>           //library for ethernet functions
#include <Client.h>             //library for client functions
#include <SPI.h>
// Ethernet settings
uint8_t hwaddr[6] = {0xDE, 0xAD, 0xBE, 0xEF, 0xBA, 0xBE}; // mac-adress of arduino
//uint8_t ipaddr[4] = {192, 168, 0, 17};                    // IP-adress of arduino
//uint8_t gwaddr[4] = {192, 168, 0, 1};                     // IP-adress of gateway ( for later DNS implementation)
//uint8_t subnet[4] = {255, 255, 255, 0};                   // subnetmask           ( for later DNS implementation)
uint8_t serverip[4] = {88,167,XXX,XXX};                    // IP-adress of server arduino sends data to
uint8_t serverport = 80;                                  // the port the arduino talks to
EthernetClient client;                      // make a new instance from type "Client" named "client", giving it
// serverip and serverport
int timeout=0;
bool req_sended = 0;
bool connected = false;                                   // yes-no variable (boolean) to store if the arduino is connected to the server
int i = 0;                                                // variable to count the sendings to the server
// heure
//int refresh=0;
int top=0;
int last_top=0;
int seconde=50;
int seconde2=0;
int minute=59;
int heure=23;
long last_time=0;
int dizaine;
long freq=0;
void setup(void)                                          // setup-function runs at the startup of the arduino
{ pinMode(9, OUTPUT);
  digitalWrite(9, HIGH);
Serial.begin(9600);                               // start the serial port
Serial.println("demarrage...");
Ethernet. begin(hwaddr);                  // start up ethernet
  digitalWrite(9, LOW);
void loop(void)                                        // loop function runs over and over again
  freq++;
//if (((minute%5)==0&&seconde==0)&&req_sended==0)
if ((seconde==0||seconde==30)&&req_sended==0)
{ //Serial.println(seconde);
  timeout=0;
if(!connected)   {    // if "not" connected print: not connected ;)
Serial.println();
Serial.println("   <----===========---->");
//Serial.println("Not connected");
if (client.connect(serverip, 80)){                             // if connected, set variable connected to "true" and
connected = true;
//delay(100);
client.print("GET /arduino/bdd.php?temp=22");
Serial.print("GET /arduino/bdd.php?temp=22");
client.println(" HTTP/1.1");
Serial.println(" HTTP/1.1");
client.println("Host: www.google.fr");
Serial.println("Host: www.google.fr");
client.println("User-Agent: Arduino");
Serial.println("User-Agent: Arduino");
client.println("Accept: text/html");
Serial.println("Accept: text/html");
client.println("Connection: close");
Serial.println("Connection: close");
client.println();
Serial.println();
req_sended=1;
else{
Serial.println("Cannot connect to Server");         //  else block if the server connection fails (debugging)
while (!client.available() && timeout<200)  {
timeout++;    if(timeout==200){Serial.print("Time out !");    Serial.println(timeout);}    delay(25);  }
Serial.print("Delay : ");Serial.println(timeout);
//delay(500);                                                //
while (client.connected() && client.available()) {          // when connected and availabe:
char c = client.read();                                    // read the answer of the server and
Serial.print(c);                                            // print it to serial port
//Serial.println();                                            //
client.stop();                                              //  stop the connection and set
connected = false;                                           //  "connected" to false
//delay(1000);
horloge();
   if(top==2){top=0; //on remet le compteur des tops seconde à 0
      req_sended=0;
      //Serial.println();Serial.print("freq : ");Serial.println(freq);
      freq=0;}
int horloge()
   if(millis()-last_time>=500)
   { last_time=millis();
    top++;
    if(top==2){seconde+=1;}//incrementation des secondes toutes les 2x 500ms
   if(seconde>59)//incrementation des minutes
     {seconde=0; minute=minute++;}
    if(minute>59)//incrementation des heures
         {minute=0;heure=heure++;}
    if(heure>23)
     {heure=0;}
   //---------- affichage heures min sec et séparateurs
   //if(seconde%2==0){lcd.setCursor(8, 1); lcd.print(" ");}//si secondes sont paires, affiche separateur droit
   //else{lcd.setCursor(8, 1); lcd.print(":");}              //sinon affiche le separateur gauche
  dizaine=((heure*60+minute)/10);
   //affiche_heure();
return dizaine;
return top;
UDP sketch :
// FADER DIODE SUR PORT 9       //
// EN UDP AVEC SCRIPT PHP AJAX  //
// IP: 192, 168, 0, 10          //
// PORT 8888                    //
#include <SPI.h>       // needed for Arduino versions later than 0018
#include <EthernetUdp.h>        // UDP library from: bjoern@cs.stanford.edu 12/30/2008
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 0, 10 };           // ip in lan
//byte gateway[] = { 192, 168, 0, 1 };            // internet access via router
//byte subnet[] = { 255, 255, 255, 0 };                   //subnet mask
  //EthernetServer server = EthernetServer(80); //port 80
unsigned int localPort = 8888;      // local port to listen on
// the next two variables are set when a packet is received
byte remoteIp[4];        // holds received packet's originating IP
unsigned int remotePort; // holds received packet's originating port
// buffers for receiving and sending data
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
char  ReplyBuffer[] = "acknowledged";       // a string to send back
EthernetUDP Udp;
  // start the Ethernet and UDP:
  Ethernet.begin(mac,ip);
  Udp.begin(localPort);
  // if there's data available, read a packet
  int packetSize = Udp.parsePacket();
  if(packetSize)
    Serial.print("Received packet of size ");
    Serial.println(packetSize);
Serial.print("From ");
    IPAddress remote = Udp.remoteIP();
    for (int i =0; i < 4; i++)
      Serial.print(remote, DEC);
      if (i < 3)
        Serial.print(".");
    Serial.print(", port ");
    Serial.println(Udp.remotePort());
    memset(packetBuffer, 0, UDP_TX_PACKET_MAX_SIZE);
    // read the packet into packetBufffer and get the senders IP addr and port number
    Udp.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE);
    Serial.println("Contents:");
    Serial.println(packetBuffer);
    analogWrite(9, atoi(packetBuffer)); //utiliser la valeur reçu pour allumer la led
  //delay(250);
</code>
PHP script for udp :
<code>
<?php
$valeur_led = $_POST["led1"]; //  récupération de la valeur transmise en méthode POST
$host="88.167.XXX.XXX";  //  Adresse ip défini dans le code arduino
$port=8888;    // Port défini dans le code arduino
$socket = socket_create(AF_INET, SOCK_DGRAM, SOL_UDP);
socket_sendto($socket, $valeur_led , strlen($valeur_led), 0, $host, $port);
socket_close($socket);
An Idea?
Thank u for your help
flyaway
This is the script where udp doesn't work:
// mode client             //
// FONCTIONNEL             //
#include <SPI.h>
uint8_t ipaddr[4] = {192, 168, 0, 10};                    // IP-adress of arduino
uint8_t gwaddr[4] = {192, 168, 0, 254};                     // IP-adress of gateway ( for later DNS implementation)
uint8_t serverip[4] = {88,167,233,135};                    // IP-adress of server arduino sends data to
//byte ip[] = {88,167,233,135};           // ip in lan
//IPAddress server(88,167,233,135);
EthernetUDP Udp;
// heure
//int refresh=0;
int top=0;
int last_top=0;
int seconde=50;
int seconde2=0;
int minute=59;
int heure=23;
long last_time=0;
int dizaine;
Ethernet. begin(hwaddr,ip,gwaddr,subnet);                  // start up ethernet
// Ethernet.begin(mac,ip);
  listen_udp();
if (seconde==59)
connected = true;
//delay(100);
client.println();
Serial.println();
else{
else {
delay(200);                                                //
//delay(1000);
   horloge();
   if(top==2){top=0; }//on remet le compteur des tops seconde à0
int horloge()
    top++;
    if(heure>23)
     {heure=0;}
   //affiche_heure();
return dizaine;
return top;
void  listen_udp()
  if(packetSize)
      if (i < 3)
        Serial.print(".");
Thank you again
SurferTim
This is incorrect:
There is no dns server ip. That follows the ip. Like this:
Ethernet. begin(hwaddr,ip,dns,gwaddr,subnet);                  // start up ethernet
If you are not using dns you can use the gateway ip
Ethernet. begin(hwaddr,ip,gwaddr,gwaddr,subnet);                  // start up ethernet
See if that is better.
flyaway
Hello SurferTim,
You know what?
That's working good !!!!!!!!!!
Thank you so much.
Bye
Fly
Sorry for my english ;)
flyaway
Me again ;)
All is ok on local server
Now I try to upload PHP files on distant server, client function is ok but UDP doesn't work.
Probably IP settings...
Bye
SurferTim
That looks like you are trying to receive UDP packets with a function name of listen_udp(), but unless your router forwards the UDP packet and performs a Network Address Translation on it, you will not get it from a public ip address. You would be limited to receiving (server) from localnet ips only. But client is ok anywhere.
flyaway
Thank you for reply,
My router (freebox) is setup to translate UDP abd TCP port 8888 on 192.168.0.10:8888.
I don't know if PHP server socket module is enabled... How can I check it?
Fly
flyaway
For information this is the warning I get:
Warning: socket_sendto() [function.socket-sendto]: unable to write to socket [101]: Network is unreachable in /mnt/165/sdb/a/b/roupet/arduino/udp_control_led.php on line 10
SurferTim
That usually means you are referring to a localnet address that does not exist. If the NAT in the router is functioning, you should access it by using the public ip assigned to the wan interface on the router. Can you ping the public ip of your router from that server?
flyaway
I have a PHP wamp server running on a PC behind this router and I'm able to reach it with public ip from anywhere.
When I try to make arduino running as a web server that's ok too from anywhere with public ip.
Is that the warning means that udp function is enabled on server? (the server is a free server provided by my internet provider).
