Topic: loops (Read 7852 times) previous topic - next topic
timothysg1
Code: [Select]
#include "IRremote.h"
int RECV_PIN = 0;
IRrecv irrecv(RECV_PIN);
int brightness = 0;    // how bright the LED is
int fadeAmount = 5;
void setup()  {
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  irrecv.enableIRIn();
void cmd_one() {
    // do one LED sequence here
    analogWrite(9, brightness);
    brightness = brightness + fadeAmount;
  if (millis() - lastRun > 50) {
      if (brightness == 0 || brightness == 255) {
          fadeAmount = -fadeAmount ;
  lastRun = millis();
void cmd_two() {
    analogWrite(11, brightness);
  lastRun = millis();
// check for incoming RF data
if (irrecv.decode(&results)) {
    Serial.println(results.value, HEX);
    if (results.value==0x8B77887) {
     num = 1  ;
  do_task(num);
void do_task(int num) {
  switch (num) {
    case 1:
      cmd_one();
    case 2:
      cmd_two();
and now i get the folowing errors (see image)
AWOL
The error messages are fairly self-explanatory - you haven't told the compiler about the variables you are using, before you use them.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
timothysg1
and how do i do that?
KirAsh4
lastRun needs to be a long, so declare it at the top of your sketch
Code: [Select]
long lastRun;  As for 'results', I don't see where that's being defined either.  That's something you need to figure out from the IR library you're using.
timothysg1
i thanks for tha code with lastrun....
i solved that results thing to now only num is the problem, the error says " 'num' was not declaired in this scope" and      num = 1  ; is marked and "do_task(num)" too
how declair i this (and wher)?
Code: [Select]
#include "IRremoteInt.h"
long lastRun;
int RECV_PIN = 0;
decode_results results;
int fadeAmount = 5;
void setup()  {
  pinMode(9, OUTPUT);
void cmd_one() {
  lastRun = millis();
void cmd_two() {
  lastRun = millis();
  switch (num) {
    case 1:
      cmd_one();
    case 2:
      cmd_two();
     num = 1  ;
  do_task(num);
KirAsh4
AWOL already responded with one solution, declaring it in the call itself with
Code: [Select]
void do_task(int num) or you can declare it like you do any other variable already, at the top of your code with simply
Code: [Select]
int num;
timothysg1
then... i am sorry
becaus i don't understaand what you, and AWOL are saying
i dont dow How i declair it in that, do you meen that instaed of putting the decoded values in cmd_one in do_task(num)
if zo how can i make the difrence between al the difrent ir data codes?
KirAsh4
Code: [Select]
void cmd_one() {
    lastRun = millis();
Something else to note: this sequence changes the LED brightness every 50 cycles.So let's do some calculations:
LED brightness goes from 0 to 255.  fadeAmount is set to 5.  So that's 255/5 = 51 steps to go from 0 to 255.
Steps happen every 50ms, so that's 2550ms (2.55 seconds) to go from 0 to 255 brightness.  Or a little over 5 seconds to go from 0 to full brightness and back down to 0.
Given that tasks aren't precise, it will be a bit more than that, meaning the task won't run at exactly 50ms each time.  it might run at 53ms, or 57ms ... everything takes time in Arduino land.  So, if you're okay with a 5+ second fade on and back off, then you're good to go.  If not, then lower the 50ms compare statement to a smaller number and the fade will go faster:
Code: [Select]
if (millis() - lastRun > 50) // <-- change that 50 to a lower number to go faster, or larger to go slower
AWOL
Quote
then... i am sorry becaus i don't understaand what you, and AWOL are saying
You've already had help defining another variable - what's the problem?
KirAsh4
then... i am sorry
Exactly the way either options are written.  AWOL method
Code: [Select]
void do_task(int num)  // <-- that declared 'num' as an INT right in the call or you can do it the other way, which is to declare the variable like you are already doing for 'lastRun' and 'RECV_PIN', just add another line that says
Code: [Select]
int num;
But do one or the other, don't do both.  but you write them in exactly as they're written here.  Nothing to change, nothing to substitute.
Groetjes.
KirAsh4
Quote
I think the problem here is that he's never programmed before and I can certainly understand the frustration.  I deal with kids in a teaching environment too and see this every day.  I show them how to do something and 5 seconds later they ask the exact same thing.  Patience is a virtue. :)  I don't mind explaining something a second time ... or third ... or ...
timothysg1
thats right it's the first time that i programmed
now, back to the prgramme, i have no errors but i did used the 2 at the same time
AND now it doesn't matter what butten i push on my remote my led goes one and of when i push a button again....
Code: [Select]
int num;
long lastRun;
int RECV_PIN = 0;
int fadeAmount = 5;
void setup()  {
  pinMode(9, OUTPUT);
void cmd_one() {
    //  if (brightness == 0 || brightness == 255) {
          fadeAmount = +fadeAmount ;
  lastRun = millis();
void cmd_two() {
  lastRun = millis();
  switch (num) {
    case 1:
      cmd_one();
    case 2:
      cmd_two();
    if (results.value==0x8B73AC5) {
     num = 1  ;
      num = 2 ;
  do_task(num);
   irrecv.resume();
AWOL
What do your debug prints tell you?
timothysg1
pleeze do not kill me
because i dont know what "debug prints" are/or how i find them...
AWOL
You've got Serial.println statements in your sketch. They're there to show what your program is doing, in the serial monitor.
