Loading...
Pages: [1]   Go Down
Author Topic: controlling a super-bright led 3,5 watt  (Read 281 times)
Italy
Offline Offline
Full Member
View Profile
do you think this may work?
Code:
   // Esempio 01: accendi il led appena è premuto il pulsante
    #define LED 7                // LED connected to the digital pin 7
    #define BUTTON 9              // pin input button
    int  val = 0;                 // status input   pin
      pinMode(LED, OUTPUT);       //  pin as output
      pinMode(BUTTON, INPUT);     // pin as input
      val = digitalRead(BUTTON);  // read the pin value and save it
      // control that input is HIGH (button pressed)
      if (val == HIGH) {
        digitalWrite(LED, HIGH);  // led  turn on
      else {
        digitalWrite(LED, LOW);   // led  turn off
Logged
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
If you want to start a fire, then yes.
A few observations:
* The 2N2222 is not good for 1A
* Why is there a 10k resistor in the current return path
* If the LED gets warm (and it will), it's forward voltage will go down --> more current --> gets even warmer ... etc
Constant current LED drivers are the way to go. Either get one on ebay for almost no money or build one (most likely more expensive).
Logged
• Upload doesn't work? Do a loop-back test.
• There's absolutely NO excuse for not having an ISP!
• Your AVR needs a brain surgery? Use the online FUSE calculator.
My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets...
• Microsoft is not the answer. It is the question, and the answer is NO!
Italy
Offline Offline
Full Member
View Profile
um.. you are right
this is the specs of the 2N2222T i bought:
Quote
Manufacturer Part No: 2N2222A
ROHS: Yes
Current Rating: 0.8A
Voltage Rated: 40V
Transistor Type: NPN
Features: General Purpose
Package: TO-92
so if i use a resistor that limit the ampere to 0,7A it should be fine.. (altought i will lose a bit of light), or i may just use another transistor model that support 1A (as the 2SC1384)
Quote
i corrected the resistors position
Quote
the LED will not be permanently ON, it will be installed on a replica gun to simulate the fire of the shot
i also changed the power supply of the led, now i connected it directly to the arduino 5volt
« Last Edit: April 11, 2012, 12:09:22 pm by onesky » Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
You are running a 3.5W LED through a 2W resistor? I suppose that would be OK for short bursts.
Logged
Pages: [1]   Go Up
Print
Jump to:
