Loading...
Pages: 1 [2]   Go Down
Author Topic: If a program could program itself?.... (AI)  (Read 1706 times)
Offline Offline
Jr. Member
View Profile
I also looked into genetic algorithms / genetic programming back in the late 90's / early 2000s. It's not hard to come up with a language where every statement is syntactically valid (i.e. it does something, which may or not be what you want) and a fitness function (a way to evaluate a program to determine if it's closer or further away from a desired solution than other instances of a program).
LISP is good because a list can also be a program. Create a million lists at random, execute them all with your dataset, pick the best 50% or so, making sure that the fitness function also has a component that selects smaller programs over larger programs. Then cross-breed the programs (exchange parts of successful lists with parts of other successful lists). That's one iteration. Do a few million iterations and eventually you've got a program that does something like what you want.
The problems: it takes a LONG time to evaluate all the programs, and you might have to have some sort of timeout criterion to prevent endless loops. It takes a LONG time to do all the iterations you need to satisfy your fitness function. Once you've satisfied your fitness function enough, you have something that works for your test dataset - that might not handle all the data you throw at it. The more complicated a thing you want, the longer it will take. Not all problems can be solved with GP: you need a problem that lets you know when you're getting closer to a solution.
See it in action here:
http://alphard.ethz.ch/gerber/approx/default.html
(needs Java)
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Virtually any (interpreted) script language can reprogram itself in a sense. For example VB with its "Execute" function lets you execute an arbitrary string. So it could generate code and then execute it. Ditto for Lua.
Logged
Offline Offline
God Member
View Profile
After thinking about this some more... a human could write a routine that over-writes a memory address leading to a crash, in this case the human has a finger and hits the reset button, the computer program running on the computer can't do that, unless it's somehow able to protect itself from any kind of crash, and after reading all these comments, it made me think and, it's the human drive to achieve something that's not been done before (or in some cases, has many many countless times) giving a program a self consciousness would be the difficult part smiley-grin - because it could rewrite it's own memory space, it could search and explorer resources on the computer to 'find things to do' oh what's this new binary file? is it executable? what's in it, unless a computer develops the ability of a curiosity as we humans do, I can't quite see AI taking off..
but hypothetically speaking.. if it did? and someone managed to write a program that got hell bent on being better than any human and just to prove who's really the best it develops some kind of virus to teach us all a lesson how far could the thing go?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Would it post here, asking for help?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Would it post its code?
(edit)
Would it use code tags if it did?
Logged
Netherlands
Online Online
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
came accros this one (again)
Real stupidity beats artificial intelligence every time. Terry Pratchett
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
What is that, like zombies vs. robots?
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
