Topic: Honeywell Gauge Pressure sensor (Read 10167 times) previous topic - next topic
PC90
Im trying to wire up and code a Honeywell gauge pressure sensor to an uno as part of my final year collage project. Does anybody have any experience with using such a pressure sensor? I have attached an image of the sensor and datasheet. Any replies would be greatly appreciated  :)
retrolefty
Looks pretty simple to use with an arduino. Just wire the devices ground to arduino ground pin, device +5vdc pin to arduino 5v pin, and devices signal output to a arduino analog input pin. Then you can use analogRead() commands to convert the reading to a digital value you can use in your sketch.
Lefty
PC90
Hi Lefty Thanks for the quick reply,
Im using the arduino for just a small aspect of my project so I would only be a novice when it comes to programming so please bear with me.
Ive used the following code but seem to be getting very fluctuating readings:
int analogPin = 2;     //  connected to analog pin 2
                       // outside leads to ground and +5V
int samples[8];
int i;
int pressure=analogRead(analogPin);
  Serial.begin(9600);          //  setup serial
  for (i=0;i<=7;i++){ // gets 8 samples of pressure
  pressure = analogRead(analogPin);    // read the input pin
  long pressure = 950 + pressure / 8.5;  //convert it to milli bars
  Serial.print("\t pressure = ");
  Serial.print(pressure);   // print the pressure
  Serial.println(" mb");
  delay(5000);   // wait 5 second before next sample
An example of my reading would be it would start at a value of say 750mb, then go 0mb..0mb then when I apply pressure using a syringe it would jump up to 1bar,But then go 0mb..0mb then 1bar etc.
retrolefty
I'll let more knowlegable software types comment on your sketch. However it doesn't seem correct to have two variables used both named pressure, one a int and global in scope and the other defined as a automatic variable inside loop() as a long variable and then both used in the same expression:
I'm suprized that doesn't generate some kind of compiler error, but again I'd rather a software guru type comment on that.
Lefty
Blake11911
Hello
Im a bit of a noob myself but..
"int analogPin = 2;     //  connected to analog pin 2"
On the Uno I thought Analog Pin 2 was represented by A2 in the compiler, the digital pins are 0-13, The Analogs being A0, A1, A2, etc
mikeZ337
there are several pressure range listed in the datasheet, check the right values for Null and Sensitivity on page 32
sample code, not tested
Code: [Select]
#define ADC_HONEYWELL 2 // Arduino analog pin
const float Null = 0.50; // Null VDC; datasheet Page 32
const float Sensitivity = 266.6;  // Sensitivity mV/psi; datasheet Page 32
  Serial.print("P: ");
  Serial.print(getPressure());
  Serial.println("mbar g");
  delay(5000);
float getPressure(void) {
  float pressurePSI,pressureMBAR,pressureVDC;
  int pressure;
  pressure = analogRead(ADC_HONEYWELL);
  pressureVDC = (float)pressure * 0.0048828125; // (5/1024 = 0.0048828125)
  pressureVDC = pressureVDC - Null;
  pressurePSI = pressureVDC / Sensitivity * 1000;
  pressureMBAR = pressurePSI * 68.948;
  return pressureMBAR;
duemilanove / OSX & WIN
Arduino & Teensy: http://bit.ly/13rbdtQ
PC90
Thank you so much for the help! Got it to work perfectly
Arizanov
Hi can you reattach
I have SB69-100V
0...100 psig
0.5....4.5 V out
Can i connect directly to arduino without resistor
retrolefty
Hi can you reattach
I have SB69-100V
0...100 psig
0.5....4.5 V out
Given that minimum information, yes it can be wired to an arduino analog input pin. A datasheet listing would be nice to confirm.
Lefty
Arizanov
http://www.fullgauge.com/PDF/PCT-400.pdf
This is a controller + pressure transducer
for him don`t have datasheet
But have SCHEMATIC FOR TRANSDUCER
Brown: 5Vdc
Green: Ground
White: Output
retrolefty
Brown: 5Vdc
Green: Ground
White: Output
Again, given what you have shown it should be OK. I would suggest you first power up the sensor independently and apply pressure tests to the sensor while measuring the output signal with a digital multimeter. If you see no signal higher then +5vdc then you should be good to go.
Lefty
