Topic: web server su SD card (Read 15521 times) previous topic - next topic
pablos71
#30
Apr 15, 2012, 01:21 pm Last Edit: Apr 15, 2012, 01:39 pm by pablos Reason: 1
Ho modificato il prog origininale del tinyweb questo ti permette di caricare su browser qualsiasi file e qualsiasi dimensione
presente su sd, sul serial monitor vedi i file che la pag htm sta caricando
Code: [Select]
#include <SPI.h>
#include <Ethernet.h>
#include <Flash.h>
#include <SD.h>
#include <TinyWebServer.h>
const int SD_CS = 4;
const int ETHER_CS = 10;
byte ip[] = { 192, 168, 2, 177 };
static uint8_t mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
boolean file_handler(TinyWebServer& web_server);
boolean index_handler(TinyWebServer& web_server);
TinyWebServer::PathHandler handlers[] = {
  {"/", TinyWebServer::GET, &index_handler },
  {"/" "*", TinyWebServer::GET, &file_handler },
  {NULL},
const char* headers[] = {"Content-Length",NULL};
TinyWebServer web = TinyWebServer(handlers, headers);
boolean has_filesystem = true;
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
void send_file_name(TinyWebServer& web_server, const char* filename) {
  if (!filename) {
    web_server.send_error_code(404);
    web_server << F("Could not parse URL");
    TinyWebServer::MimeType mime_type = TinyWebServer::get_mime_type_from_filename(filename);
    web_server.send_error_code(200);
    web_server.send_content_type(mime_type);
    web_server.end_headers();
    if (file.open(&root, filename, O_READ))
      Serial << F("Read file "); Serial.println(filename);
      web_server.send_file(file);
      file.close();
      web_server << F("Could not find file: ") << filename << "\n";
boolean file_handler(TinyWebServer& web_server) {
  char* filename = TinyWebServer::get_file_from_path(web_server.get_path());
  send_file_name(web_server, filename);
  free(filename);
  return true;
boolean index_handler(TinyWebServer& web_server) {
  send_file_name(web_server, "INDEX.HTM");
  return true;
  pinMode(SS_PIN, OUTPUT); // set the SS pin as an output
  digitalWrite(SS_PIN, HIGH); // and ensure SS is high
  pinMode(ETHER_CS, OUTPUT); // Set the CS pin as an output
  digitalWrite(ETHER_CS, HIGH); // Turn off the W5100 chip! (wait for
  pinMode(SD_CS, OUTPUT);       // Set the SDcard CS pin as an output
  digitalWrite(SD_CS, HIGH); // Turn off the SD card! (wait for
  card.init(SPI_FULL_SPEED, SD_CS);
  volume.init(&card);
  root.openRoot(&volume);
  Ethernet.begin(mac, ip);
  web.begin();
  Serial << F("Ready to accept HTTP requests.\n");
    web.process();
L'esperienza è il tipo di insegnante più difficile ....
Prima ti fa l'esame e poi ti spiega la lezione.
brunol949
Solo una domandina ( non riesco ad attendere fino a questa sera ) : posso convertire qualunque immagine in Base64 ? o ci sono limiti di grandezza e formato ?
Per la conversione non credo
Tieni presente che poi l'immagine sara' parte integrante del file html
Le mie opere : Flusso correnti nell'impianto fotovoltaico http://arduino.webveneto.net/energy_control/     PING ed E.Mail http://arduino.web
brunol949
Code: [Select]
#include <Flash.h>
Ma la libreria flash a cosa serve ?
Ovviamente se l'intenzione e' quella di mettere tutto su SD
Grazie
pablos71
#33
Apr 15, 2012, 06:46 pm Last Edit: Mar 04, 2015, 06:15 pm by pablos Reason: precisazione su utilità della Flash
Quote
Grazie
la flash.h gestisce le stringhe caricandole su flash e non su Sram che poi è diventata funzione F()
   char c = (*this);
   if (!c) break;
   stream.print(c); // print in char form
brunol949
#34
Apr 15, 2012, 08:16 pm Last Edit: Apr 15, 2012, 08:18 pm by brunol949 Reason: 1
la flash.h gestisce le stringhe e gli operatori
    char c = (*this);
    if (!c) break;
Ma un uso intensivo non portera' alla distruzione della flash ??
Sempreche' serva a scrivere in flash e non sia un nome di comodo
maxvetro
Scusate ma ho avuto un impiccio con l'ivi o delle risposte..
PABLOS sto testando  il tinyweb da te modificato
Code: [Select]
#include <SPI.h>
#include <Flash.h>
#include <SD.h>
  {NULL},
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
  if (!filename) {
      file.close();
  free(filename);
  return true;
  return true;
  volume.init(&card);
  web.begin();
    web.process();
e sembra essere tutto funzionante , ora continuo a giocare ...
grazie
