Topic: Setting up the second SPI port on the Arduino Uno (Read 5702 times) previous topic - next topic
diesel
Nick,
OK, I will look around and see if someone has done something like that. Thanks for your help!!
-diesel
nickgammon
Here's an example:
// bit banged SPI pins
const byte MSPIM_SCK = 4;  // port D bit 4
const byte MSPIM_SS  = 5;  // port D bit 5
const byte BB_MISO   = 6;  // port D bit 6
const byte BB_MOSI   = 7;  // port D bit 7
// for fast port access (Atmega328)
#define BB_MISO_PORT PIND
#define BB_MOSI_PORT PORTD
#define BB_SCK_PORT PORTD
const byte BB_SCK_BIT = 4;
const byte BB_MISO_BIT = 6;
const byte BB_MOSI_BIT = 7;
// control speed of programming
const byte BB_DELAY_MICROSECONDS = 4;
// Bit Banged SPI transfer
byte BB_SPITransfer (byte c)
  byte bit;
  for (bit = 0; bit < 8; bit++)
    // write MOSI on falling edge of previous clock
    if (c & 0x80)
        BB_MOSI_PORT |= _BV (BB_MOSI_BIT);
        BB_MOSI_PORT &= ~_BV (BB_MOSI_BIT);
    c <<= 1;
    // read MISO
    c |= (BB_MISO_PORT & _BV (BB_MISO_BIT)) != 0;
   // clock high
    BB_SCK_PORT |= _BV (BB_SCK_BIT);
    // delay between rise and fall of clock
    delayMicroseconds (BB_DELAY_MICROSECONDS);
    // clock low
    BB_SCK_PORT &= ~_BV (BB_SCK_BIT);
  return c;
  }  // end of BB_SPITransfer
void setup () { }
void loop () { }
You'll have to change the constants to suit.
More info:
diesel
Nick,
Thanks I will give that a try. I confirmed it was xck0 pin not being accessible that was the problem on the arduino mega. Bought a seeduino mega board that has the xck0(pe2) accessible, got spi on uart working on this board.
Another question, can you switch uart line back over to serial mode by just doing Serial.begin(#)? I would think you could. Should you make any other register changes?
Thanks,
-diesel
nickgammon
Serial.begin should do it, as far as I know.
More info:
