Topic: ATmega2560-Arduino Pin Mapping (Read 8430 times) previous topic - next topic
s-lighte
Hi Community,
in the last days i am working on an project using the Arduino Mega 2560. On planning my Pin using i found some bugs in the ATmega2560-Arduino Pin Mapping.
if i get it right there are some labels (such as PWM) in the 'Mapped Pin Name' at the wrong row ( its an mixed up which pin numbers are the right one...)
in the Attachment is an OpenOffice Calc and PDF file with the corrected Table. ( I hope so ;-) )
I will also post it here as tab separated table :
Code: [Select]
Arduino Mega 2560 PIN mapping table
ATmega 2560 Pin out Arduino Mega
Function
NR Name Function Function Function Mapped Pin Name Function Function Datasheet
1 PG5 OC0B Digital pin 04 PWM
2 PE0 RXD0 PCINT8 Digital pin 00 RX0 (USART0 Receive Pin, Programming Data Input or Pin Change Interrupt 8)
3 PE1 TXD0 Digital pin 01 TX0 (USART0 Transmit Pin or Programming Data Output)
4 PE2 XCK0 AIN0 (USART0 External Clock  Input/Output)
5 PE3 OC3A AIN1 Digital pin 05 PWM
6 PE4 OC3B INT4 Digital pin 02 PWM
7 PE5 OC3C INT5 Digital pin 03 PWM
8 PE6 T3 INT6
9 PE7 CLKO INT7 ICP3
10 VCC VCC
11 GND GND
12 PH0 RXD2 Digital pin 17 RX2 (USART2 Receive Pin)
13 PH1 TXD2 Digital pin 16 TX2 (USART2 Transmit Pin)
14 PH2 XCK2 (USART2 External Clock  Input/Output)
15 PH3 OC4A Digital pin 06 PWM
16 PH4 OC4B Digital pin 07 PWM
17 PH5 OC4C Digital pin 08 PWM
18 PH6 OC2B Digital pin 09 PWM
19 PB0 SS PCINT0 Digital pin 53 SS (SPI Slave Select input or Pin Change Interrupt 0)
20 PB1 SCK PCINT1 Digital pin 52 SCK (SPI Bus Serial Clock or Pin Change Interrupt 1)
21 PB2 MOSI PCINT2 Digital pin 51 MOSI (SPI Bus Master Output/Slave Input or Pin Change Interrupt 2)
22 PB3 MISO PCINT3 Digital pin 50 MISO (SPI Bus Master Input/Slave Output or Pin Change Interrupt 3)
23 PB4 OC2A PCINT4 Digital pin 10 PWM
24 PB5 OC1A PCINT5 Digital pin 11 PWM
25 PB6 OC1B PCINT6 Digital pin 12 PWM
26 PB7 OC0A PCINT7 OC1C Digital pin 13 PWM
27 PH7 T4
28 PG3 TOSC2
29 PG4 TOSC1
30 RESET RESET
31 VCC VCC
32 GND GND
33 XTAL2 XTAL2
34 XTAL1 XTAL1
35 PL0 ICP4 Digital pin 49
36 PL1 ICP5 Digital pin 48
37 PL2 T5 Digital pin 47
38 PL3 OC5A Digital pin 46 PWM
39 PL4 OC5B Digital pin 45 PWM
40 PL5 OC5C Digital pin 44 PWM
41 PL6 Digital pin 43
42 PL7 Digital pin 42
43 PD0 SCL INT0 Digital pin 21 SCL (TWI Serial Clock or External Interrupt0 Input)
44 PD1 SDA INT1 Digital pin 20 SDA (TWI Serial Data or External Interrupt1 Input )
45 PD2 RXD1 INT2 Digital pin 19 RX1 (USART1 Receive Pin or External Interrupt2 Input)
46 PD3 TXD1 INT3 Digital pin 18 TX1 (USART1 Transmit Pin or External Interrupt3 Input)
47 PD4 ICP1
48 PD5 XCK1 (USART1 External Clock  Input/Output)
49 PD6 T1
50 PD7 T0 Digital pin 38
51 PG0 WR Digital pin 41
52 PG1 RD Digital pin 40
53 PC0 A8 Digital pin 37
54 PC1 A9 Digital pin 36
55 PC2 A10 Digital pin 35
56 PC3 A11 Digital pin 34
57 PC4 A12 Digital pin 33
58 PC5 A13 Digital pin 32
59 PC6 A14 Digital pin 31
60 PC7 A15 Digital pin 30
61 VCC VCC
62 GND GND
63 PJ0 RXD3 PCINT9 Digital pin 15 RX3 (USART3 Receive Pin or Pin Change Interrupt 9)
64 PJ1 TXD3 PCINT10 Digital pin 14 TX3 (USART3 Transmit Pin or Pin Change Interrupt 10)
65 PJ2 XCK3 PCINT11 (USART3 External Clock  Input/Output or Pin Change Interrupt 11)
66 PJ3 PCINT12
67 PJ4 PCINT13
68 PJ5 PCINT14
69 PJ6 PCINT 15
70 PG2 ALE Digital pin 39
71 PA7 AD7 Digital pin 29
72 PA6 AD6 Digital pin 28
73 PA5 AD5 Digital pin 27
74 PA4 AD4 Digital pin 26
75 PA3 AD3 Digital pin 25
76 PA2 AD2 Digital pin 24
77 PA1 AD1 Digital pin 23
78 PA0 AD0 Digital pin 22
79 PJ7
80 VCC VCC
81 GND GND
82 PK7 ADC15 PCINT23 Analog pin 15
83 PK6 ADC14 PCINT22 Analog pin 14
84 PK5 ADC13 PCINT21 Analog pin 13
85 PK4 ADC12 PCINT20 Analog pin 12
86 PK3 ADC11 PCINT19 Analog pin 11
87 PK2 ADC10 PCINT18 Analog pin 10
88 PK1 ADC9 PCINT17 Analog pin 09
89 PK0 ADC8 PCINT16 Analog pin 08
90 PF7 ADC7 PCINT15 Analog pin 07
91 PF6 ADC6 PCINT14 Analog pin 06
92 PF5 ADC5 TMS Analog pin 05
93 PF4 ADC4 TMK Analog pin 04
94 PF3 ADC3 Analog pin 03
95 PF2 ADC2 Analog pin 02
96 PF1 ADC1 Analog pin 01
97 PF0 ADC0 Analog pin 00
98 AREF Analog Reference
99 GND GND
100 AVCC VCC
is this forum the right way to get such corrections to the side?
have fun and sunny greetings
Stefan
