Loading...
Pages: [1]   Go Down
Author Topic: SMT oops  (Read 301 times)
Liverpool, UK
Offline Offline
Jr. Member
Arduino rocks
View Profile
I bought a couple of these for a project:
They look nice and chunky in the picture, I should be able to solder that no problem.
Unfortunately, they are only 3mm square.
Oops.
I was thinking I'd use ordinary network cable wire (solid core) soldered (carefully! and through a magnifying glass) to each land to make legs, which could then be arranged to drop into a DIP chip holder... any better ideas? I'm a bit concerned about cooking the chip, should I go for a mega hot tip to reduce heating times, or a low temp to avoid exceeding the max data sheet temp (260 C)?
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Quote
image or link missing?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Liverpool, UK
Offline Offline
Jr. Member
Arduino rocks
View Profile
So it is.... I definitely pasted it in smiley-sad
Trying again: http://uk.farnell.com/jsp/search/productdetail.jsp?SKU=1971743
Logged
Denmark
Offline Offline
Full Member
New on the Arduino platform...
View Profile
WWW
Forget using solid core network cable, you'll just break off the pads!
Use some 0,1 or 0,15mm magnet wire, that is soft enough that you won't rip off the pads when arranging the connections.
// Per.
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Keep in mind that the 260°C is for the reflow oven where the entire package is subjected to that heat.
There's a reason why hobby-vendors supply these on breakout boards.
Logged
www.cmiyc.com - A guide to being an Enginerd
Liverpool, UK
Offline Offline
Jr. Member
Arduino rocks
View Profile
I've ordered some 175oC solder paste, and some thin wire.... I will either try with the heat gun (to solder all leads at the same time), or the iron for a very brief moment, hopefully the low melting temp + my smallest bit will be good enough.
Agree about the breakout boards, I'm too cheapskate to  buy them.
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Personally, my time is worth something.  I wouldn't want to spend 2-3 hours trying to solder to a chip that I might ultimately burn up.  Factor in time and frustatio, you'll find that breakout boards can be an awesome value.
Logged
Offline Offline
Edison Member
View Profile
Id suggest 30 gauge stranded wire,  it'll be a pain and how are you gonna mount that now?
Logged
Pages: [1]   Go Up
Print
Jump to:
