Loading...
Pages: [1]   Go Down
Author Topic: current transducer.  (Read 244 times)
uk
Offline Offline
Sr. Member
View Profile
hi
im planning on using this current transducer to monitor current on a project, can i just use the output from it (2.5 to 4.5v) without any other circuitry straight into an analog input?
thank you
in the speck sheet it quotes Rl  (load resistance) should be greater than 2k should there be a 2k resistor to ground?
http://www.farnell.com/datasheets/51628.pdf
« Last Edit: May 04, 2012, 08:04:15 am by jonisonvespa » Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Yes.
In the spec sheet it quotes Rl  (load resistance) should be greater than 2k should there be a 2k resistor to ground?
No.  The input impedance of the Arduino is >2K so you should be able to connect the output directly to it.  Just hook "5V" to +5V, "0V" to Ground, and "OUT" to an analog input pin.
Logged
uk
Offline Offline
Sr. Member
View Profile
thanks very much john
Logged
Pages: [1]   Go Up
Print
Jump to:
