Loading...
Pages: [1]   Go Down
Author Topic: "Year 2000 problem" in Arduino  (Read 1240 times)
Changchun
Offline Offline
Newbie
View Profile
WWW
The micros( ) in wiring.c function using the the variable timer0_millis, which is defined volatile unsigned long timer0_millis , the maximum value is oxFFFFFFFF . It adds MILLIS_INC on  each Timer0 interrupt(at 12MHZ clock, the MILLIS_INC = 1).  After  (0xFFFFFFFF/MILLIS_INC) Timer0 interupts,  timer0_millis will become 0 on next interrupt, so the delay( ) function will  occur the "Year 2000 problem" , because it uses if (((uint16_t)micros() - start) >= 1000) ,which the micros() is equal  timer0_millis.
At about 68 days, it maybe accur "Year 2000 problem".
by Rom Huang
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
All this is well known so:-
So what is your point or question?
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
I would assume that is why the millis() reference page (http://arduino.cc/en/Reference/Millis) says:  "This number will overflow (go back to zero), after approximately 50 days."
The solution is very simple and well documented:
http://arduino.cc/playground/Code/TimingRollover
Logged
www.cmiyc.com - A guide to being an Enginerd
Pages: [1]   Go Up
Print
Jump to:
