Topic: Arduino and LM35DZ Centigrade thermistor. (Read 1 time) previous topic - next topic
axo95b
Ok I can't figure out what im doing wrong here. I have this thermistor on a bread board I have +5v from arduino going to the +Vs I have Vout going into the Arduino analog port A0 and the ground going to arduino's ground. Here is the data sheet for the LM35DZ (http://www.ti.com/lit/ds/symlink/lm35.pdf). Here is the Code I am using to see the output.
int SensorPin =A0;
int Temp =0;
  int Temp = analogRead(SensorPin);
    Serial.println (Temp);
delay (600);
Here is what I get back.
53
52
53
52
52
52
52
52
52
53
52
52
52
52
What am I doing wrong? Im just confused because a few hours ago I was working on this and it was about 65 degrees F in here and my reading was 64-63 and now Im still messing with it trying to figure out what is going on 4 hours later it is 53 degrees F roughley and It's reading this. It is like the V out is being converted to fahrenheit or something.
n1spx
the LM35 output is 10mV per degree C.  You are displaying the raw value you read, and not converting it first.
Code: [Select]
should be something like:
Code: [Select]
  int Temp = analogRead(SensorPin) * 500 / 1024;
for Centigrade
or
Code: [Select]
  int Temp = (analogRead(SensorPin)  * 900 / 1024 ) + 32;
for Fahrenheit
That is a rearrangement of * 5 / 1024 * 100  and    (* 9 / 5) + 32
* 5 / 1024 gives the actual voltage on the pin.
* 100 converts that to the number of 10 mV steps
(* 9 / 5) + 32 converts C to F if desired
Note: as wired, you cannot measure less than 0c
Note: change 5 in the above formulas if the arduino is changed from running at 5v.
axo95b
Hey thanks for the response I have no idea where you are getting the number 1024. I took the code you gave me and put it in like this.
Quote
int SensorPin =A0;
int Temp =0;
  //int Temp = analogRead(SensorPin);
 delay (600);
Now my output in the serial monitor is around 13 or 14. and My Vout is .25v ( on my multi- meter) I assume the /1024 has something to do with the resolution on the analog header but my mind cant grasp why I would divide it by the total resolution.
Boffin1
There are 1024 analog " steps" read by the analog input
45 years of editing projects with a knife and soldering iron, then I found Arduino !
n1spx
Quote
int SensorPin =A0;
int Temp =0;
 delay (600);
It shouldn't matter, but you are defining Temp twice.  Remove the "int" before Temp =  in the loop.
Quote
I'm not sure why that is yet.
Quote
Is your room 25C (~80F) ?
Your above readings of 52-53 also equate to ~.25v.
52 * 5 / 1024 = ~.254
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
