The code is nearly right but you only do one column per refresh not all of them.
You are only sourcing one LED's current per shift register pin so that is fine but check on the data sheet that the total package current is OK, it depends on what type of shift register you get, that is given by the letters before the 595 bit, you might have to use LS or HS type. The darlingtons are good for 500mA per pin.
OOOOOOOohhhh omg I understand now
Firstly, the datasheet for the 595s Im getting say the max continuous output current is 35mA I think,
http://www.jaycar.com.au/products_uploaded/ZC4895.pdf But I dont know if thats per pin or not?
Ok now to the good part
, I think I have got it, and I wrote up the code, not psuedocode:
This works if the ULN2803 inverts I have read that it does but im still not sure, on your site It says they do or is that for the FET's?
const int latchPin = 4;
const int clockPin = 3;
const int dataPin = 2;
byte displayData [ ] = {
B11111111,
B10000001,
B10111101,
B10100101,
B10100101,
B10111101,
B10000001,
B11111111,
B11011011,
B11111111,
B11111111,
B11111111};
int rowCount = 0;
long int refreshDue;
long int refreshTime = 10;
pinMode(dataPin, OUTPUT); //Data
pinMode(clockPin, OUTPUT); //Clock
pinMode(latchPin, OUTPUT); //Latch
if(millis() >= refreshDue){
refreshDue = millis() + refreshTime;
refreshDisplay();
void refreshDisplay(){
if (rowCount>=12)rowCount=0;
byte rowData;
byte col1Data;
byte col2Data;
rowData = displayData[rowCount];
if (rowCount<=7){
col2Data=B00000000;
col1Data=byte(rowCount+1);
}else if (rowCount>=8{
col2Data=byte((rowCount-8)+1);
col1Data=B00000000;
digitalWrite(latchPin, LOW);
shiftout(dataPin, clockPin, MSBFIRST, col2Data);
shiftout(dataPin, clockPin, MSBFIRST, col1Data);
shiftout(dataPin, clockPin, MSBFIRST, rowData);
digitalWrite(latchPin, HIGH);
rowCount ++;
(I also used alot of your code, thanks bro
There is one minor flaw in this code...
instead of refreshing left to right, or right to left (which is what I wanted)
it refreshes or the bit walks like this (_ means that its not used shift register pin)
00000001 0000 _ _ _ _
00000010 0000 _ _ _ _
00000100 0000 _ _ _ _
00001000 0000 _ _ _ _
00010000 0000 _ _ _ _
00100000 0000 _ _ _ _
01000000 0000 _ _ _ _
10000000 0000 _ _ _ _
00000000 0001 _ _ _ _
00000000 0010 _ _ _ _
00000000 0100 _ _ _ _
00000000 1000 _ _ _ _
Also I believe you mean HC, I cant find any HS595's anywere
P.S: I saw your post whilst I was posting a reply to the other one
, I dont mean to spring the surprise, I was using just a photodiode and hoping it would work, when I realised the part that I ordered from sparkfun wasnt a photodiode but rather a reciever Lol, fail, so then I just thought since the instructable I was following before was a load of crap and I might as well actually use the reciever it could give me a better result
This is the part: TSOP38, can be found here:
http://www.sparkfun.com/products/10266But I might have to order from somewhere else as they only take credit card and use something like this:
http://www.jaycar.com.au/productView.asp?ID=ZD1952&form=CAT2&SUBCATID=976#1which is way too overpriced for me
I would prefer to use this:
http://www.electus.co.nz/productView.asp?ID=6149&CATID=33&keywords=&SPECIAL=&form=CAT&SUBCATID=140 but I dont know how to use it with the emitter, all examples use reciever breakouts and stuff
Thanks Mike
