Author Topic: two leds, one output?  (Read 458 times)
Hannover, Germany
Hi all,
I'm getting old  smiley-wink I forgot the proper way, and the search of these words gives too much results. I want to drive two leds with one PWM output pin (left eye and right eye of my evil spider  ]smiley). Serial or parallel? (For the latter: one or two resistors?).
best regards
Andreas
http://danimathblog.blogspot.com
#define true '/'/'/'
#define false '-'-'-'
20 LEDs are enough
If the forward voltage is low enough --> serial. If it is to high --> parallel with separate resistors.
Hannover, Germany
Brett vorm Kopf (plank in front of head  smiley). Standard LED, U_F = 2.25 V; this gives the forward voltage of 4.5 V. So: 5 V - 4.5 V = 0.5 V; R = U/ I is here R = 0.5V / 10 mA = 50 Ohm. Is this correct? (Just to be sure).
Thanks, Danke, merci, gracie
Andreas
« Last Edit: April 13, 2012, 11:47:49 am by danimath » Logged
Manchester (England England)
Solder is electric glue
Is this correct?
Yes  smiley
Hannover, Germany
Thanks, Danke, merci, gracie Mike! I've done this stuff 40 years ago, so the knowledge got a little bit rusty  smiley-wink
Andreas
