Topic: calculate relative direction to destination (Read 5199 times) previous topic - next topic
AWOL
Well, your debug trace doesn't give any indication of how long it took (hint), but I'd probably go for continuous (1Hz) updates from the GPS, and do a rolling average of lat/long.
Quote
it still does not work good from my side
I'm sorry to hear that.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
cutebuddy6
i am just working on the ranges but not able to define it properly so i need help in defining the ranges if you can do me a favour
AWOL
You can't define the range; the range is simply the distance from where you are to where you want to be, and will obviously vary.
cutebuddy6
only worried about the direction
Quote
if ( finaldir < 20 && finaldir > 340 )//if the final direction is +20 or -20 it should go straight
            Serial.println("Straight");
            myLCD.print ("Go Straight");
            //motorForward();//car Forward
            //steering('C');//Steering Centered
          if(finaldir >180 && finaldir < 339)
            Serial.print("Straight");
            Serial.println("Left");
            myLCD.print ("L");
            //motorForward();
            //steering('L');
          if(finaldir > 20 && finaldir < 179)
            Serial.println("Right");
            myLCD.print ("R");
            //motorForward();
            //steering('R');
AWOL
Code: [Select]
Doesn't seem very likely, does it?
strykeroz
Code: [Select]
Also you have some gaps where if the value is 179 through 180, 339 through 340, or exactly 20 (as examples) there's no result as you've not tested for >= or <=.
"There is no problem so bad you can't make it worse" - retired astronaut Chris Hadfield
cutebuddy6
AWOL
#37
Apr 13, 2012, 09:46 pm Last Edit: Apr 13, 2012, 09:54 pm by AWOL Reason: 1
Well, as usual, you're ignoring what you're being told.
How many times do you need to be told that adding the same number twenty times and then dividing by twenty is a waste of time?
How many times have I told you that static analysis of software is about the least productive way of debugging?
Again
Code: [Select]
Can you list all the values of "finaldir" which are going to trigger this condition?
(Hint: It's a very short list)
