Topic: Using 595 shift register to interface with LCD via SPI (Read 2071 times) previous topic - next topic
electricsashimi
I am following this tutorial: http://arduino.cc/playground/Main/LiquidCrystal, written fairly recently about using a 595 shift register to communicate with the LCD instead of connecting it directly thus saving more  input/output pins. The tutorial includes its own modified version of the LCD library but when I try to compile the sample code on the tutorial with the LCD library updated, I get a compiling error.
Also, can some one confirm if the schematics are correct? I was looking at another tutorial using the 595 and there was a capacitor from a pin to ground, but this one doesn't.
CrossRoads
The only place there should be a capacitor is from the Vcc pin to ground.
Any schematic with a cap on any othe pin is incorrect.
Nick Gammon
Take a look here:
http://arduino.cc/forum/index.php?topic=74666.0
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
juanh0238
it is fixed I uploaded an updated library that works with Arduino 1.0 and older ones, in the previous one I was using Arduino 22, but please let me know if you find anymore problems.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
