Topic: Suggested fix to SPI.begin() (Read 963 times) previous topic - next topic
Nick Gammon
There is a problem in SPI initialization as discovered in this thread:
http://arduino.cc/forum/index.php/topic,100671.0.html
The problem code is here from SPI.cpp:
void SPIClass::begin() {
  // Set direction register for SCK and MOSI pin.
  // MISO pin automatically overrides to INPUT.
  // When the SS pin is set as OUTPUT, it can be used as
  // a general purpose output port (it doesn't influence
  // SPI operations).
  pinMode(SCK, OUTPUT);
  pinMode(MOSI, OUTPUT);
  pinMode(SS, OUTPUT);
  digitalWrite(SCK, LOW);
  digitalWrite(MOSI, LOW);
  digitalWrite(SS, HIGH);
  // Warning: if the SS pin ever becomes a LOW INPUT then SPI
  // automatically switches to Slave, so the data direction of
  // the SS pin MUST be kept as OUTPUT.
  SPCR |= _BV(MSTR);
  SPCR |= _BV(SPE);
Bearing in mind that SS (slave select) is normally active low, what the above code does is briefly bring SS low, between these lines:
Depending on the clock polarity, it may appear to the device that it has been selected, and then a bit clocked. To fix this we simply need to bring SS high before making it an output, then the pin is not driven low and immediately high again, like this:
  // SPI operations).
  SPCR |= _BV(MSTR);
  SPCR |= _BV(SPE);
More info:
Graynomad
That makes sense, maybe suggest in on the developer's mailing list or the bug reporting page (wherever that is).
_____
Rob
Coding Badly
maybe suggest on the bug reporting page (wherever that is).
http://code.google.com/p/arduino/issues/list
P18F4550
I know im stil sat in the stone age but this is just one more reason im still using IDE_18 & spi.h because it works, why SPI.h was included in later versions of IDE i dont know, when got new version nothing worked
Nick Gammon
Submitted as issue 888 (sort of like 666 but worse).
More info:
