Topic: Anyone can give me many examples of I2C and Serial SPI communication? (Read 1 time) previous topic - next topic
creativen
I am doing my project using Arduino UNO and Arduino Ethernet board W5100, now I pile it up together.
After reading some sources, they said that SPI communication using 4 lines, here:
http://dev.emcelettronica.com/i2c-or-spi-serial-communication-which-one-to-go
It means when I connect my arduino UNO to my computer, it uses SPI to communicate.
It also means that when I connect my arduino UNO to my Ethernet Board using 4 pins, it uses also SPI to communicate, doesn't it? Correct me if I am wrong.
Then, what the example of I2C communication?
What about the LAN jack on the Ethernet Board, what type of communication it uses? SPI or I2C?
I am newbie in this electronic device, and kindly hope your help.
Thank you. :D
Grumpy_Mike
Quote
No it uses the serial port through the USB connector.
creativen
Oh I think Serial and SPI is the same...
Because SPI (Serial Peripheral Interface)...
Can you give me other example for the I2C and SPI communication?
Grumpy_Mike
Quote
It is not.
He computer talks through an aysynchronous serial protocol. SPI is as you say Serial Periphal Interface a totally diffrent thing.
This is sounding like a homework question.
What sort of example do you want, just look at some of my projects they contain examples of both those.www.thebox.myzen.co.uk
nickgammon
http://www.gammon.com.au/i2c
http://www.gammon.com.au/spi
http://www.gammon.com.au/forum/?id=10894  (serial)
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
