« on: April 14, 2012, 12:17:44 pm » |
I will build custom microcontrollers around what features are most voted for. The finished products will be sold so make sure you select which extra features you would most like it to have.
Belgium
« Reply #1 on: April 14, 2012, 12:37:04 pm » |
You are going to produce microcontrollers? That's a big investment  Or are you going to produce Arduino like boards with ATmega microcontrollers? Maybe a board with Xbee and a H-brigde is an idea, would be popular for robots.
« Last Edit: April 14, 2012, 03:26:11 pm by Bajdi »
« Reply #2 on: April 14, 2012, 01:37:10 pm » |
boards with ATmega or microchip microcontrollers. Sorry for confusion
20 LEDs are enough
« Reply #3 on: April 14, 2012, 03:01:54 pm » |
I can build custom boards. The answer is always dependent on the usecase. I wonder how you come to the conclusion that you can make any money that way.
Delray Beach, FL USA
« Reply #4 on: April 14, 2012, 03:09:22 pm » |
At the moment, my dream arduino would be identical to the Arduino Uno R3, but would have a dadgum jumper (or microswitch) on the auto reset instead of a trace you have to cut to disable reset and solder pads you have to join to turn reset back on.
Phoenix, Arizona USA
Where's the beer?
« Reply #5 on: April 14, 2012, 03:20:56 pm » |
Would this work? http://www.seeedstudio.com/depot/seeeduino-v30-atmega-328p-p-669.html?cPath=132_133Not an UNO, though...
a, b = b, a+b
« Reply #6 on: April 14, 2012, 03:21:17 pm » |
@udo
come on... let him have his fun. I do believe that more arduinos to choose from is always a better thing... :-)
I am currently building my dream arduino myself :-)
20 LEDs are enough
« Reply #7 on: April 14, 2012, 04:06:51 pm » |
So am I ;I
But this guy is going to build other people's dreams? Where is the fun in that?
Grand Blanc, MI, USA
Online
"We're a proud service of the Lost Electricity Reclamation Agency"
« Reply #8 on: April 14, 2012, 04:14:06 pm » |
Try a small electrolytic capacitor from the reset pin to ground. Value not terribly critical, 10µF - 47µF. 10µF works for me.
a, b = b, a+b
« Reply #9 on: April 14, 2012, 04:14:35 pm » |
this is what I need: a pet engineer, who I can keep at home, so I can stop bugging all the knowledgeable people of this forum with my inane questions. - completely off topic @udo klein (assuming you are German just based on the name) Do you know of any good/cheap/easy to deal with companies in Germany which do PCB fabrication for people like us?
SE USA
Online
@ssh0le
« Reply #10 on: April 14, 2012, 04:52:12 pm » |
one with a power switch... which is why I made my own with a simple toggle switch
"The old Europe"
Bootloaders suck!
« Reply #11 on: April 14, 2012, 05:10:12 pm » |
Forget about that. Unless you need it quickly and have quasi unlimited funds. For the price you'd pay for a single 160x100mm prototype board you can get a lot more from the many Chinese manufacturers and have it fedex-ed to your door within one week.
• Upload doesn't work? Do a loop-back test. • There's absolutely NO excuse for not having an ISP! • Your AVR needs a brain surgery? Use the online FUSE calculator. • My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets... • Microsoft is not the answer. It is the question, and the answer is NO!
« Reply #12 on: April 14, 2012, 09:08:49 pm » |
I would want software support for integers with more than 32 bits.
Firenze, Italy
Dislessia portami via
« Reply #13 on: April 15, 2012, 03:53:36 am » |
This is going to be very usefull!
The brightest flame burns quickest
UK
« Reply #14 on: April 15, 2012, 05:21:23 am » |
Build them yourself! I can go from concept to using it in a couple of hours. I rarely breadboard stuff now. It is cheap enough to make boards. You can spend quite a bit like I did but you don't need to. There are methods for laser printing onto magazine paper then ironing it onto a copper board, remove paper leaving toner in place and then etch in cat litter tray. I don't know the specifics as I have a three tank commercial setup but I know people that use this method and it works.
