Topic: Need Help: Problem with Pointers & passing to functions (Read 768 times) previous topic - next topic
Sev
So, I have a function setDataSource which is designed to take an address of an object as an argument and set up a pointer to it inside a class.  I can't figure out how pass a pointed-to object to it.
That is, I can get this to work:
combinedDataObject data;
foo.setDataSource(&data);
However, I cannot get this to work:
combinedDataObject *p;
foo.setDataSource(&p);
I get compiler errors -- no matching function for call to 'setDataSource(combinedDataObject**)'
Here's the source for the setDataObject function, which is part of class basicTimerObject.  combinedDataObject is derived from timeObject.
void basicTimerObject::setDataSource(timeObject * timeNow)
   dataSource = timeNow; // timeObject *dataSource is a protected member of basicTimerObject
Any input would be appreciated, thanks!
Delta_G
Because you are passing a pointer to a pointer there.  If setDataSource expects a pointer then do:
*p = &data;
foo.setDataSource(p);
And then you are passing a pointer to the function that points to data.
Ad hoc, ad loc, and quid pro quo.  So little time - so much to know!  ~Jeremy Hillary Boob Ph.D
Sev
Whoops.  I did make a mistake there, I should have had:
combinedDataObject *p = &data;
doesn't work.
setDataSource doesn't expect to be passed a pointer, it expects to be passed the address of an object.  I'm trying to get it to work with a pointer instead.  The problem is that I've got various objects that expect to be passed a reference to the global data object, which they store internally as a pointer, and now I'm trying to use an object which has one of these objects inside of it, along with a reference to the global data object.  I'm trying to initialize the member object with the pointer stored in the object which contains it, rather than by passing it the address directly with &data as it expects.
Sorry if I'm not explaining this well; I have problems with pointers.  %)
WizenedEE
doesn't work.
Yes. p is a pointer, and &p is the address of the pointer -- a pointer to a pointer. You don't want to have the &, you just want to say
Code: [Select]
Quote
that's the definition of a pointer
Delta_G
Right, and the pointer is holding the address of an object, &data.  Change the &p to just a p and it will work.
Sev
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
