Loading...
Pages: [1]   Go Down
Author Topic: Arduino + Stellarium with Meade lx200 Protocol  (Read 5234 times)
Offline Offline
Newbie
View Profile
i'm trying to interface stellarium and an Arduino based telescope motor through the Telescope plugin using the meade lx200 protocol as described here-->http://www.meade.com/support/LX200CommandSet.pdf.
I have successfully answered to the getRA command but the getDEC command gives me problems:
in fact in the protocol documentation it says that i have to send back the value of the Declination as
Code:
sDD*MM#
i think s is the sign(+ or -) and i give random numbers on D and M (eg.
Code:
+45*00#
. this is what i send back through Serial.
But in the log message it says:
Code:
15445, 11:34:00.890104Z: Lx200Connection::sendCommand(Lx200CommandGetRa)
15445, 11:34:00.890104Z: Lx200Connection::writeFrontCommandToBuffer(Lx200CommandGetRa): queued
15445, 11:34:00.890104Z: Lx200Connection::sendCommand(Lx200CommandGetDec)
15445, 11:34:00.890104Z: Connection::performWriting: writeNonblocking(5) returned 5; #:GR#
15445, 11:34:05.904390Z: Lx200Connection::resetCommunication
15445, 11:34:05.921391Z: Lx200Connection::sendCommand(Lx200CommandGetRa)
15445, 11:34:05.921391Z: Lx200Connection::sendCommand(Lx200CommandGetDec)
15445, 11:34:15.952965Z: Lx200Connection::writeFrontCommandToBuffer(Lx200CommandGetRa): queued
15445, 11:34:15.952965Z: Connection::performWriting: writeNonblocking(5) returned 5; #:GR#
15445, 11:34:16.018969Z: Connection::performReading: readNonblocking returned 11; 03:00:00#
15445, 11:34:16.018969Z: Lx200CommandGetRa::readAnswerFromBuffer: RA = 03:00:00
15445, 11:34:16.018969Z: Lx200Connection::writeFrontCommandToBuffer(Lx200CommandGetDec): queued
15445, 11:34:16.077972Z: Connection::performWriting: writeNonblocking(5) returned 5; #:GD#
15445, 11:34:16.138976Z: Connection::performReading: readNonblocking returned 7; +45*00#
15445, 11:34:16.138976Z: Lx200CommandGetDec::readAnswerFromBuffer: error: '+' or '-' expected
15445, 11:34:16.138976Z: Lx200Connection::resetCommunication
15445, 11:34:16.202979Z: Lx200Connection::sendCommand(Lx200CommandGetRa)
15445, 11:34:16.202979Z: Lx200Connection::sendCommand(Lx200CommandGetDec)
15445, 11:34:16.202979Z: Connection::performReading: readNonblocking returned 2;
I don't know how to solve the
errot '+' or '-' expected
Thanks in advance for any help
Francesco
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
The documentation says on page 10:
SdsDD*MM#
Set target object declination to sDD*MM or sDD*MM:SS depending on the current precision setting
Returns:
1 - Dec Accepted
0 – Dec invalid
you need to prepend Sd for the command  - did you include that?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
The
Code:
SdsDD*MM#
is only for Stellarium to tell the telescope which are is the Declination of the target he has to look for. The
Code:
Sd
before
Code:
sDD*MM#
is only a command to tell the scope Setdeclinationto...
what i was looking to was how should be the declination written by The telescope for the Pc
anyway thanks for the help
Francesco
P.S.
i tried it anyway and it doesn't worked, as expected smiley-mad smiley-mad
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Can you post the library you're using / the code of the sketch?
Maybe that helps us to understand the problem as I don't know now how the log you posted is generated.
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
The log i posted is generated by the stellarium telescope plugin, i'll post the sources of the plugin only as attachment, you have to take a look at Server-->the lx200 ones.
and for my sketch code, here it is:
Code:
String stringOne = "";
  if (Serial.available()){
    while (Serial.available()>0){
      char a=Serial.read();            // Stores current byte
      stringOne += String(a);          // Append current Byte to message String
      delay(10);
    if (stringOne == "#:GR#"){         // if command received = get RA do...
      Serial.println("03:00:00#");
    if (stringOne == "#:GD#"){         // if command received = get DEC do...
      Serial.print("+45*00#");
    stringOne = "";
Logged
Offline Offline
Newbie
View Profile
I tried everything and i think there is only one chance more, to try connecting the telescope to arduino IDE and through the serial monitor send #:GD# and see exactly what it gets.
If somebody with that mount could try it, it would be very appreciate. smiley-lol smiley-lol
Thanks
Francesco
Logged
Offline Offline
Newbie
View Profile
I solved the problem two weeks ago, but want to share what the problem was;
the problem consisted in how i send the DEC back to stellarium, in fact i used the
Code:
Serial.println()
so it received the RA and after the string it added a
Code:
\n
which stellarium after appends to the DEC string and tries to analize it instead of the "+" or "-", i solved simply by using
Code:
Serial.print()
which doesn't append anything to what i send back.
Thanks anyway for the help
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Actually if you look at the length of the string you'll see the RA is sent as 11 characters, but there are only 9 printable ones, so I think it's almost certainly adding 0x0D,0x0A (CRLF) - both of which are separately echoed as blank lines in the log in fact...
Logged
Offline Offline
Newbie
View Profile
I found this project on web, works great on Arduino, but I never test with a real telescope:
ArduGoTo
https://sites.google.com/site/ardugoto/
Logged
Espoo, Finland
Offline Offline
God Member
"Oops, try again..."
View Profile
Google translator cannot find that page??? What language that is?
Cheers,
Kari
Logged
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
Offline Offline
Newbie
View Profile
langauge is spanish. he is stating the page will be used for documentation and the steps he will take to development the code for his goto mount via Arduino Uno andUSB motor Shield using stepper motors
« Last Edit: October 11, 2012, 10:05:13 pm by ninosr » Logged
Offline Offline
Newbie
View Profile
Hi, read this
Code:
http://www.stargazing.net/kepler/altaz.html
can help you
after that and understand how this work can drive for this
Code:
http://www.jgiesen.de/astro/astroJS/siderealClock/
instead calculate everything manually.
I doing the same, but now i have the problem of down't know what to do with what I received.
I'm work with a digital compass and accelerometer
Logged
Pages: [1]   Go Up
Print
Jump to:
