Loading...
Pages: [1]   Go Down
Author Topic: RGB/ FSR pressure sensor, code not doing what it says.  (Read 526 times)
Offline Offline
Newbie
View Profile
I have hooked up my arduino and used the code below. What the code says isn't what the code is doing. When there is no pressure, the RGB is still on. The pressure sensor is working, but not changing the colours right. Here is the code and a photo.
Any help ??
Thanks
//Setup all pins
int sensPin = 2;    // set the touch sensor (analog) input pin on Arduino
int redPin = 3;    // set the PWM (analog) output pin on Arduino controlling the red anode
int grnPin = 5;        // set the PWM (analog) output pin on Arduino controlling the green anode
int bluPin = 6;    // set the PWM (analog) output pin on Arduino controlling the blue anode
//Setup all initial values
int val = 0;            // initial value for touch sensor input
int state = 1;        // initial machine state
//Initialize variables
int redVal;         // pulse width variable for red anode
int grnVal;         // pulse width variable for green anode
int bluVal;        // pulse width variable for blue anode
  pinMode(redPin, OUTPUT);   // set the LED pins as output
  pinMode(grnPin, OUTPUT);
  pinMode(bluPin, OUTPUT);
  val = analogRead(sensPin);           // read touch sensor values
  Serial.println(val);
  if (state == 1) {sleep();}        // turn off LED
  else if (state == 2) {redIn();}    // fade in red color
  else if (state == 3) {grnIn();}    // fade in green color
  else if (state == 4) {bluIn();}    // fade in blue color
void sleep() {
  alloff();                                  // turn off LED
  if (val > 20 && val <= 500)  {state = 2;}   // test for low pressure
  if (val > 500 && val <= 850) {state = 3;}   // test for medium pressure
  if (val > 850) {state = 4;}              // test for high pressure
void redIn() {                  // function to fade in red color and transition to other states
  grnVal = 0;
  analogWrite(grnPin, grnVal);  // turn off green in case the last state was green
  if (redVal == 255) {            // if red is at maximum, continue to light it up
    analogWrite(redPin, redVal);
  } else {                    // else fade in the red color
    redVal ++;
  if (val < 20) {state = 1;}    // turn off the LED if no pressure detected
  if (val > 500) {state = 3;}   // fade in green if pressure has increased
void grnIn() {                  // function to fade in green color and transition to other states
  redVal = 0;
  bluVal = 0;
  analogWrite(redPin, redVal);    // turn off red in case the last state was blue
  analogWrite(bluPin, bluVal);  // turn off blue in case the last state was blue
  if (grnVal == 255) {            // if green is at maximum, continue to light it up
  } else {                    // else fade in the green color
    grnVal ++;
  if (val <= 500) {state = 2;}    // fade in red if pressure has decrease
  if (val >= 850) {state = 4;}    // fade in blue if pressure has increased
void bluIn() {                  // function to fade in blue color and transition to other states
  grnVal = 0;
  if (bluVal == 255) {            // if blue is at maximum, continue to light it up
  } else {                    // else fade in the blue color
    bluVal ++;
  if (val <= 850) {state = 3;}    // fade in green if pressure has decreased
void alloff() { // function to turn off the LED
  redVal = 0;
  grnVal = 0;
  bluVal = 0;
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Code:
    bluVal ++;
can be shorter ==>
Code:
  if (bluVal < 255) bluVal ++;
also other colors smiley
I would rethink the code,
you have 3 leds that should overlap
RED [0..512] => 0..255..0
GREEN [256-768] ==> 0..255..0
BLUE [512-768] ==> 0..255
That would give something like the following code - give it a try
Code:
//Setup all pins
  int val = analogRead(sensPin);           // read touch sensor values
  if (val < 256)
    redVal = val;
greenVal = 0;
blueVal = 0;
  else if (val < 512)
    redVal = 512 - val;
greenVal = val-256;
blueVal = 0;
  else if (val < 768)
    redVal = 0;
greenVal = 768-val;
blueVal = val-512;
    redVal = 1023-val;
greenVal = 1023-val;
blueVal = 255;
  display(redVal, greenVal, blueVal);
void display(int r, int g, int b)
  analogWrite(redPin, r);
  analogWrite(grnPin, g);
  analogWrite(bluPin, b);
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Pages: [1]   Go Up
Print
Jump to:
