Loading...
Pages: 1 [2] 3 4   Go Down
Author Topic: Tutorial for hacking a CP2102 USB from ebay and uploading a sketch to an Atmega  (Read 6306 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Do you make them with dip atmegas?
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
what are you looking for? standalone boards?
but in DIP style?
maybe Anatools.com will help, and his Anarduino kit:
http://www.anatools.com/anarduino/
http://www.anatools.com/anarduino/inst.jsp
I found him great to deal with and very nice.
I used a few of these...they are great and are assembled in like 5 minutes.
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
@msev - yes.
Also DIP ATMega1284's. Extra IO (32 total), dual hardware serial port.
You can see some of my designs at the link in my signature. Gotta find my FTP password so I can upload some more pic's.
Or here for a minimal component '328:
http://store.nkcelectronics.com/arduino-runtime-board-rev-b.html
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
I'm looking for a design with the dip package that would ideally have such a pinout for programming pins that it would be directly plug-in friendly for the modified cp2102. Probably I'll have to modify some .brd file of an exsisting  minimal arduino project.. It would be nice if there was a topic, a collection of all minimal arduino projects together smiley-grin
Logged
Salem, Oregon
Offline Offline
Full Member
Arduino rocks but sometimes it rolls
View Profile
When the arduino has an onboard cap in series from DTR pin to the chip's reset, then a cap is not needed on the CP2102 module.
Thanks for that - I'd been wondering why I'd seen the 0.1uF cap added to the board that RandallR pictured thinking that it shouldn't be needed if the 'arduino' has it's own 0.1uF cap on the reset line.
I guess the idea was to avoid having an extra cap on each clone you build?  Too late for me, I always do that.
I'm posting just to confirm for the OP that I bought a pair of the same boards (or at least appear to be the same) that RandallR pictured from dealextreme and the "fix" was as simple as cutting the trace that goes to the RST pin and running a small wire from DTR.  No 0.1uF cap needed if your target board already has it.
I also had to swap the TX/RX lines between the CP2102 and the target board (I've seen some boards where this wasn't needed).
Hope this helps,
Brad.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Did you swap them because of the pinout on your arduino, or because the board was mislabeled (that rx was labelled as tx?)?
Logged
Salem, Oregon
Offline Offline
Full Member
View Profile
My Arduino board uses the standard FTDI pinout if that helps (I only bought the CP2102's to test).  I believe this board actually has RX/TX marked correctly since with my other TTL/USB adapter also crosses TX/RX.
FWIW,
Brad.
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
its common form what I have seen..
some mark it as to what it GOES to.. an some mark it as what it IS..
once of the first things I try to swap when an FTDI sketch upload fails..
what/where are these boards you are getting??  (that has the DTR pin broke out)
my cheapie cables only ave 4 lines (5 if you count the 3.3v pad)  5v+, GND, RX, TX..
I hve to manually hit the reset button to upload sketches.. not a problem.. but going forward.. some projects wont have a reset button at all.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
Here are the ones I bought, can't beat the price:
http://www.ebay.com/itm/370532286388?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Lefty
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
you dont have to use the 6-pin header do you?
I mean treat this like any other FTDI cable..yes?
as long as I run 5v+, GND, RX, TX to my chip.. Im good.. I can then use/tap the DTR pad from the bottom of the board to use on the DTR of the circuit Im uploading my sketch to....right?
a shame it was brought out on top like the other pins.
also is there a driver for it?
thanks
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
@msev,
a board like you describe is easy to make.
Logged
Salem, Oregon
Offline Offline
Full Member
View Profile
Nope. You can wire it up any way you choose.  I do use 6pin headers simply to keep with the standard FTDI pinout.
Note the included (very short) cable actually only has 5pins (you can see that in the picture that Lefty posted).
Quote
Sure, just get a couple of the 6pin female crimp housings (such as http://www.pololu.com/catalog/product/1905), remove the single pin plastic housing on each pin, and insert the pins in the correct order.  Or use whatever size header you want, as long as it matches your board.
I'd suggest testing the pinout first just in case :-)
Quote
You don't really need to pass 5v, but you've got the idea.  I was going to post a picture of a modified board but there isn't much to show - simply a cut trace and a jumper wire.  Takes 2 minutes and seems to work great.
Quote
Yup.  I think there is a link earlier in this thread.  If not, you can find the driver here http://www.kerrywong.com/2010/07/16/an-arduino-compatible-using-cp2102/
Hope this helps,
Brad.
Logged
0
Offline Offline
God Member
Arduino rocks
View Profile
thanks for the reply..
even found it a buck cheaper on ebay too:
http://www.ebay.com/itm/130683943875?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
thanks!
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
@msev,
Are you willing to design it for me since you have a lot of experience (in Eagle)? With Dip atmega328.
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Sure - which parts do you want to keep, and how do want the connector?
Logged
Pages: 1 [2] 3 4   Go Up
Print
Jump to:
