Loading...
Pages: [1]   Go Down
Author Topic: Parts of the Arduino  (Read 142 times)
Offline Offline
Full Member
View Profile
WWW
Can the two pins above the AREF and gnd be used for anything?
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
Yes, they are the SCL/SDA pins. Are also connected to A4/A5 (D18/D19). You can confirm which with a meter.
Or write a sketch that makes one toggle, then the other, and use an LED/resistor to see which is changing.
Or a multimeter.
Or review the schematic: http://arduino.cc/en/uploads/Main/Arduino_Uno_Rev3-schematic.pdf
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Pages: [1]   Go Up
Print
Jump to:
