cologne, germany
« on: April 17, 2012, 02:26:51 am » |
Hi, I have some questions regarding the graphic equalizer IC "MSGEQ7". I want to lead the output signal of an lm386 (connected to an electret-mic) to a MSGEQ7 and 'fetch' the band-peak-values via an ARDUINO and recalculate the 7 bands into two bands. I want to display the result via two LED lines driven by two TLC59116 (:=two band peak-meter).
My first question is: In the datasheet (s. picture) of the MSGEQ7 pin 8 is connected via a 200k resistor with VDD (+5V). As I don't have a 200k resistor I would like to use 3 x 68k (=204k + tolerances). I guess that this is o.k. for a qualitative peak-meter!?
Second question: There is a 22k resistor shown at pin 5 (audio in). I saw wiring schemes without this resistor. Do I need it?
Third question: I assume that the IC with VDD=+5V needs an audio-signal with a center voltage of 2,5V (as generated from the lm386), right?
Fourth question: I assume that the seven bands (63Hz, 160Hz, 400Hz, 1kHz, 2,5kHz, 6,25kHz und 16kHz) mean "0Hz-63Hz", "0Hz-160Hz", ... and not "0Hz-63Hz", "63Hz-160Hz", ..., right?
Thanks for the answers in advance!
« Last Edit: April 17, 2012, 03:24:55 am by Joegi »
Manchester (England England)
Online
Solder is electric glue
« Reply #1 on: April 17, 2012, 03:03:03 am » |
I assume that the seven bands (63Hz, 160Hz, 400Hz, 1kHz, 2,5kHz, 6,25kHz und 16kHz) mean "0Hz-63Hz", "0Hz-160Hz", ... and not "0Hz-63Hz", "63Hz-160Hz", ..., right? No wrong on both counts it is a band centered on the frequency mentioned. It is only a low order filter so these bands might overlap for loud inputs. I would like to use 3 x 68k (=204k + tolerances). I guess that this is o.k. for a qualitative peak-meter!? That will be fine. The resistor on the audio in is to stop the left and right channel shorting out. If you have a mono input you have no need for it.
« Last Edit: April 17, 2012, 03:04:35 am by Grumpy_Mike »
cologne, germany
« Reply #2 on: April 17, 2012, 03:46:00 am » |
...but to build a two band peak-meter with one band going from (roughly) "0 to 1kHz" and the other going from "1kHz to 16kHz" I could use this formulas: Band1: (peak_63Hz + peak_160Hz + peak_400Hz + peak_1kHz) / 4 Band2: (peak_2,5kHz + peak_6,25kHz + peak_16kHz) / 3
- right?
cologne, germany
« Reply #3 on: April 17, 2012, 04:39:32 am » |
...o.k., the separation-frequency with the above formulas wouldn't be 1kHz, as the named frequencies are the center frequencies of the bands, but something between 1Khz and 2.5kHz!
Online
« Reply #4 on: April 17, 2012, 05:13:14 am » |
- right?
If that is what you want to do you are using the wrong chip, while this would give you something it would not have a very smooth frequency response, in other words there would be lots of pass band ripple. You would be better off just using a high order high pass and low pass filter.
cologne, germany
« Reply #5 on: April 17, 2012, 05:54:33 am » |
Is there any IC that has a high order high- AND low pass filter with adjustable cut-off frequency? Alternatively I could use a FFT, but on an Atmega this is too slow!(?) But nevertheless, as the look, not the quantity, is most important, I will try the MSGEQ7 (maybe I will display more than two bands to get better results)!
cologne, germany
« Reply #6 on: April 17, 2012, 06:23:48 am » |
What about the widths of the bands of the MSGEQ7. Are they all the same. That would result in little or no pass-band between 63Hz and 160Hz and much pass-band between 6.25kHz and 16kHz!?
cologne, germany
« Reply #7 on: April 17, 2012, 07:53:35 am » |
Would the "max263" IC be a feasible solution for two band filtering? One could switch the cut-off frequency fast to get a two band filter out of a one band filter!?
cologne, germany
« Reply #8 on: April 17, 2012, 08:29:24 am » |
...I read the first sentences of the max263's datasheet (at the moment I don't have time to read more) and there is written that the IC has two filter sections! Does that mean that I could use a low-Pass and a high-pass filter at the same time?
Online
« Reply #9 on: April 17, 2012, 12:19:41 pm » |
Would the "max263" IC be a feasible solution for two band filtering? One could switch the cut-off frequency fast to get a two band filter out of a one band filter!? It might be I have not used tat chip before. However the switch capacitor filtering chips I have used in the past have been a disappointment, with the switching noise getting into the pass band. Yes it looks like you an have two filters at he same time.
