Topic: Start/Stop Arduino (Read 888 times) previous topic - next topic
Zarkoff
This is a very basic question,
Other than removing the power, is there a way to stop the Arduino from processing i.e. halting the microprocessor?
Thanks,
John
RuggedCircuits
Yes, you can put it into a sleep mode:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1291420085
The QuadRAM shield: add 512 kilobytes of external RAM to your Arduino Mega/Mega2560
CrossRoads
Sure, you can put it in power down sleep mode, use a hardware interrupt to wake it up.
Err, yeah, what he said!
Zarkoff
Thanks.
I should have been more specific; is there a way put it to sleep from the IDE?  In the micro I switched from, one could stop and restart the processor from the IDE.
While I'm at it; is there a way to clear the serial monitor window?
Is there a limit to how many lines the window will accommodate?
Is there a way to capture the contents of the serial monitor window in a text file?
John
RuggedCircuits
No, the IDE can only send serial data, it cannot control the running state.
No, generally I just close it and open it again (though that resets the Arduino too)
Don't know the answer to that one.
Not easily -- you can select all the text as you would select text in a normal window, then paste it into a text editor (Notepad, for example)
You can get more powerful terminal emulator programs (BrayTerm, TeraTerm) which do allow you to clear the screen, log data to a file, etc.
The Flexible MIDI Shield: MIDI IN/OUT, stacking headers, your choice of I/O pins
florinc
Not directly. You can send through serial a command that does just that, like
if (command is SLEEP)
   go_to_sleep
Instead of the serial monitor coming with the IDE, you can use a terminal app which has this sort of capability, like CoolTerm, for example.
Zarkoff
Thanks; those are all good replies and I'll check them out.
John-
CrossRoads
I like RS232MON from EVMSoft.com as a test tool.
Can select data format (hex,text/ascii, bin, dec, float)
on both Rx & Tx, and on Tx can send repeating a file, or bursts of characters, in 1mS and up periods.
I've been using it a lot to test out a Tx card that spits out RS232 at 115,200 to see if the correct stuff was coming out,
and sending that same data into an Rx card to see if it was reacting properly.
danimath
You can use another program instead of the serial monitor. If I have to save things in a text file I use putty.
best regards
Andreas
http://danimathblog.blogspot.com
#define true '/'/'/'
#define false '-'-'-'
