Loading...
Pages: [1] 2   Go Down
Author Topic: Wifi Web Thermostat  (Read 7416 times)
Offline Offline
Newbie
View Profile
Hello everyone, I am a new user from Italy. :-)
I realized a thermostat controllable by web using an arduino with wifi shield.
My house is divided into two zones (day and night) controlled by two programmable thermostats.
I often travel for work and sometimes happen to get home earlier or later than I thought. Hence the need to have a thermostat controllable by the web.
Looking around I found great thermostats wifi with web interface but very expensive (500-700 euros), so I decided to realize this project and it works!
Materials:
Product                                                         Price      Qty       Price Tot
Arduino Uno                                                   29,90      1         29,90
Wifi Shield                                                     56,00      1         56,00
Temperature Sensor DS18B20                             2,00      2         4,00
Power Supply AC/DC 3-12V 500mA                      9,90      1         9,90
Relay 220V                                                      8,00      3         24,00
Switch                                                           30,00      1         30,00
Switch Contact 1NO/1NC                                    5,00      2         10,00
Mini adhesive backed PCB support 14.3mm           4,50      1          4,06
Box        9,00      1          9,00
Total 176,86
I installed the Arduino + wifishield, the three relays and the switch in the box.
I placed the two temperature sensors side by side with traditional thermostats, one in the day zone and the other in the night zone.
The switch is used to include/exclude the arduino or the traditional thermostats.
I then added a third relay (on the web page "auxiliary") to turn on/off a pellet stove.
Screenshot of the webpage:
I attach the code, libraries and some pdf, please use arduino-0023 (with Arduino-1.0 does not work the wifi shield library).
I also used a modified OneWire library because the original one doesn't work with long wires (about 10 meters from arduino to temperature sensors).
Suggestions for improvement are welcome!
« Last Edit: September 20, 2012, 04:41:26 am by gpanni » Logged
Offline Offline
Jr. Member
View Profile
WWW
Hi Gianni,
congratulations for your project! Very interesting.
If you want you can take a look at our project Freedomotic.com as software control for your system.
I noted that it's based on http commands so it's simple to create a specific plugin.
This is a code example for an ethernet relay board using a similar communication protocol http://code.google.com/p/freedomotic/source/browse/plugins/devices/progettihwsw-eth/src/it/cicolella/phwsw/ETHProgettiHwSw.java
Regards
Logged
Freedomotic Domotica Open Source
http://freedomotic.com
We need your help. Please contact us for contributing
0
Offline Offline
Jr. Member
there's no place like 127.0.0.1
View Profile
Looks like a nice and tidy user interface. smiley
Quote
One question>> What modifications did you do to the OneWire library?
I am asking, because I also plan to build some temperature monitoring on my heating system in the house, which is also heated by a pellet stove smiley
Logged
Offline Offline
Newbie
View Profile
Look http://www.pjrc.com/teensy/td_libs_OneWire.html  smiley
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
From back in the day when things were simple.  smiley
http://web.comporium.net/~shb/t-stat.htm
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Newbie
View Profile
Can you share with us how you did this?
I have attached a pdf in the first post with the scheme of the project.
There are few words in Italian, sorry.  smiley-confuse
Logged
Belgium
Offline Offline
Newbie
View Profile
Nice project, can you tell which WIFI shield you use ?
Logged
Offline Offline
Newbie
View Profile
I have attached a pdf in the first post.
It's in Italian, sorry.
Logged
South UK
Offline Offline
Sr. Member
View Profile
Looks nice, congratulations!
Logged
Offline Offline
Newbie
View Profile
Cool. Where did you get the 220V relay?
Logged
Offline Offline
Newbie
View Profile
Here
« Last Edit: December 15, 2012, 03:07:33 pm by gpanni » Logged
Offline Offline
Newbie
View Profile
Instead f the relay can it be used a mosfet
Logged
Manchester UK
Offline Offline
Newbie
View Profile
Hi
 I wanted to do something similar to control my heating adjusting the start time automatically if its colder so in the winter it would come on earlier depending on the outside temperature. I even though it could learn how long it takes to get to temperature depending on how cold it was and adjust accordingly.
I looked at the WIFI shields and thought I may be beter using something like this http://www.ebay.co.uk/itm/Mini-Travel-Wireless-N-WLAN-Router-Access-Point-Adapter-/300556193704?pt=UK_Computing_Wireless_Routers&hash=item45fa8b8fa8&_uhb=1 an access point with an Ethernet shield that way all the WEP/WPA stuff is done externally and maybe I can pinch 6v from the PSU to power my arduino. Its cheaper too !!
Logged
Offline Offline
Newbie
View Profile
HI, I would like to do something similar using enc28j60 chip Arduino shield.
Only a web temperature notifier :
For exemple ,if temp is below 20 deg send an email. If temp is over 25 send an email again. Is it possible. If yes how should i do with this shield?
Thanks a lot my friend.
Logged
Offline Offline
Newbie
View Profile
Hi, nice project...Is it possible to use this code with ethernet libary? If yes can you tell me how?
Thanks a lot.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
