Author Topic: Arduino Nano-Bought from dealextreme.com-D8 pin is high by default.  (Read 718 times)
Hi every one.
I had bought 2 nano-328 from dealextreme. My problem is that when i run the default blink program changing the led pin 13 to 8. the program doesn't seem to run.The output of pin D8 is high always.
When i change the led pin to D7 the sketch runs. But however the D8 pin is high.
Can any one guide to what the problem is.
Thnaks
Scotland
Have you had your Arduino fix today?
Hi - a link to the item would help - and a CLOSE in focus picture of both sides of the board may help as well. Are you getting the same fault on both boards?
Drew.
(MyPCB MANUFACTURING SERVICE)
Duemilanove - UNO - Leonardo - Mega 1280 - Mega 2560 - Pro
& Way too many custom boards.
Yes same thing on both boards. the link to the pics is http://www.goodluckbuy.com/arduino-nano-v3-0-avr-atmega328-p-20au-board.html
Scotland
Maybe a board manufacturing fault - make sure you are setting the pin to input OR output with the pin LOW.
Drew.
I will try that in the evening.
Thanks
Forum Administrator
I find plain exciting
Please note that the so called "Arduino" boards sold by dealextreme are unauthorised clones. This means that if they don't work (and we're getting a lot of feedback about that) you are on your own.
Official Arduino boards will be replaced by authorised resellers no questions asked.
thanks
m
Bologna
L'anima sta all'uomo come l'uomo sta alla macchina
Philip Torrone posted an article about Arduino unauthorized clones. IMHO It's worth reading
http://blog.makezine.com/2012/04/18/soapbox-counterfeit-open-source-hardware-knock-offs-101/
twitter: @shineangelic
Denmark
I think its getting more and more common, people buying cheap stuff from ebay or China and when its not working, they come crying about it.
Are people just getting more and more stupid ?
I have done with what you said, but same result.
Now like people have said that this is a counterfeit board. Now what should i do to revive my nano.
Thanks
I thinke this question is the fuse CKOUT has been program,you can re-program the bootloader if you have ISP download cable,the bootloader file is in the path: \arduino-0022\hardware\arduino\bootloaders\atmega\ATmegaBOOT_168_atmega328.hex,
Fuse setting as follow:
atmega328.bootloader.low_fuses=0xFF
atmega328.bootloader.high_fuses=0xDA
atmega328.bootloader.extended_fuses=0x05
atmega328.bootloader.lock_bits=0x0F
good luck!
Thanks arduino_lover
I have burned the bootloader through arduino ide and the boards work fine.
Thanks Again
