Topic: 2 pins at the same time (Read 1 time) previous topic - next topic
Tegra
So i got this program and it works fine. It is supposed to generate a pwm signal of a predetermined frequency by using a function.
The downside however is that i can only run this function on one pin at a time. How can i get it to start and finish on 2 pins simultaneously (for example pin 10 and 11)?
For my project i need 4 pins to run in pairs (with delays between the pairs)
Code: [Select]
void frecventa(byte targetPin, int highRate, int lowRate, int n)
/* targetPin=nr of pin used
   highRate=High state duration
   lowRate=Low state duration
   n=number of repeats*/
    for (int i=0; i < n; i++)
    digitalWrite(targetPin, HIGH);
    delay(highRate);
    digitalWrite(targetPin, LOW);
    delay(lowRate);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
frecventa(9,16,16,70);
delay(2000);
frecventa(10,16,16,70);
delay(2000);
AWOL
Have you looked at the blink without delay example?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
MarkT
Have you though about passing an array of pin numbers instead of a single pin number to the function?
Tegra
how do i do that, can i get an example?
AWOL
Any function that takes an array or pointer as an argument should give you a clue.
